New FTTC installation speed issues
- Re: New FTTC installation speed issues
28-09-2016 4:15 PM
HI I’m new to the forum and FTTC, but I have an interesting issue.
I ‘upgraded’ to 80/20 FTTC from ADSL last week, initially I didn’t get any speed increase as my profile hadn’t been updated, after this was rectified my download speed increased to 40Mbps and 20 up. I ran the BT wholesale tests and the maximum theoretical download was around 40, a lot less than the estimate (I live 200M from cabinet). I then moved the router to the master socket, I didn’t think would make much difference, when I now ran the BT test the max achievable was around 77Mbps, although I was only getting 40Mbps, during the TAP3 BT test I could download at around 66Mbps.
The router says that the connection is 80 down and 20 up
I have logged a fault 2 days ago, my profile on the PN member page was at 40, but has since jumped to 78Mbps, brilliant I thought, that’s it fixed, last night my downloads has dropped to 13Mbps !!! Still havent had any feedback, it just frustrating more than anything else.
What could be causing the slow speeds L
28-09-2016 4:54 PM
Its clear from looking at your screenshots that's something's not right, I see you have raised a fault and currently waiting for a reply as far as I'm aware due to the bad weather it's 5 days at the moment for a response.
The best thing I can advise is you wait for the faults team to carry out there tests . Also if possible post your statics there available on troubleshooting tab> Helpdesk in your Hub (please blank out your plusnet username in the statics)
James
