New FTTC connection.... OR Modem.
nozzer
I'm soon to go for a new FTTC connection having been on ADSL2+ for ages. I am aware that PN supply a hub as part of the deal, but I would also like the option of continuing to use my trusty Billion Bipac 7800N router.
This means buying an OR modem presumably, or does OR still supply them in any case when they do the installation? If I have to buy one, anyone got a recommendation for the best type/brand and is it simply a matter of plugging it in and then connecting it to the router (and re-configuring that of course)?
6 REPLIES 6
Fixes: 416
Re: New FTTC connection.... OR Modem.
OR do not install or supply modems any more.
Go onto Ebay and buy a Huawei HG612 Model 3b such as https://www.ebay.co.uk/itm/Huawei-EchoLife-HG612-3B-FTTC-VDSL-NTE-Fibre-Modem-NEXT-DAY-DELIVERY/2227...
This will work straight out of the box but you can also unlock it to monitor your VDSL statistics see: http://www.kitz.co.uk/routers/hg612unlock.htm
nozzer
Thanks @Baldrick1 . Very thorough. Just what I wanted.
nozzer
Just a thought...   as an alternative (I'm interested in comprehensive line stats monitoring), a couple more questions....   who manufacturers the latest Hub One as distributed by PN for fibre, and is it suitable for use with dslstats (http://dslstats.me.uk/index.html) which has an option for limited line monitoring on Thomson/Technicolor modem/routers?
Fixes: 416
I understand that they're manufactured by Sagecom. They are BT Home Hub 5As with tweeked firmware. They are locked down so you cannot use them with dslstats.
dannyboy75
Sagemcom 😉
nozzer
Thanks folks! That's answered that!
