New FTTC Connection Not Authenticating
Strikeforce
Hello,
I was switched over to Plusnet this evening. Everything seemed to be working ok at first.
However the connection randomly dropped, I think it coincided with adding on a static ip in your portal. I then updated my Plusnet password, as it was quite a complicated one, and was wondering if my router was failing to accept some of the special characters.. Since then I've unable to connect, the router logs keep saying PPP Authentication failed. I've tried resetting the password again but i'm still unable to connect.
If I reset the Plusnet router, it trys to connect using setup@plusdsl.net, which connects fine, but doesn't let me out of the Plusnet walled garden.
Can you check this for me please?
Kind regards
Andrew
1 REPLY
Fixes: 13
Re: New FTTC Connection Not Authenticating
Hi Andrew,
Thanks for getting in touch.
I'm pleased to see that you're back online now and have been since around 8am.
If there's anything else that crops up, just give us a shout and we'll be happy to assist.
Best Wishes,
Dave
 Dave G
