New Customer!
- New Customer!
- « Previous
- Next »
Re: New Customer!
19-01-2015 9:45 PM
Download speedachieved during the test was - 18.37 Mbps
For your connection, the acceptable range of speedsis 48.3 Mbps-69.01 Mbps .
Additional Information:
IP Profile for your line is - 69.01 Mbps
Upload speed achieved during the test was - 1.35Mbps
That second link gives me a blank table when i put my number in?
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
WBC Fixed Rate 1 -- -- Available
Other Offerings
Copper Multicast -- -- -- Available
Should i reboot the bt modem?
Re: New Customer!
19-01-2015 9:52 PM
This could possibly be congestion issue. You need to wait for staff to check? If you are around at 12am try a test again then to rule it out
Re: New Customer!
19-01-2015 9:55 PM
Yes the test is via wireless, however, i have done them all wireless for comparisons.
Ill try a check at 12am, however, i really do hope this isn't congestion, although even if it was, upload speed wouldn't suffer would it?
Re: New Customer!
19-01-2015 10:16 PM
Re: New Customer!
19-01-2015 10:42 PM
Also, sounds like you was on a bad gateway. Next time, login to the PlusNET router and click disconnect under broadband and re-connect after a short time. Rebooting the BT modem isn't a good thing
I've never rebooted mine, in the 17ish months.
Re: New Customer!
19-01-2015 10:43 PM
Just out of interest, why is it better to reboot the router rather than the modem?
Re: New Customer!
19-01-2015 10:50 PM
Just reboot the PN router if you have too, as DLM won't intervene. Also, disconnect and you'll get a new IP and hopefully it'll be PlusNET
Re: New Customer!
20-01-2015 6:35 AM
Ill reboot the router and see what i get
Re: New Customer!
20-01-2015 8:56 AM
Hope you enjoy the plusnet service (partner won't swap to plusNET, so stuck with Sky ADSL) but we get all channels, telephone, broadband and multiroom for £48 a month
I need to convince her fibre is better for gaming
Re: New Customer!
20-01-2015 9:59 AM
Is it recommended I swap out the PN router for a tp link or similar?
I have read that the ISp supplied one isn't that good?
Re: New Customer!
20-01-2015 10:14 AM
Otherwise it's pretty stable, and it has 15 devices on the wireless (access point was for my benefits only)
Time Since Power-on: 32 days, 22:45:44
Re: New Customer!
20-01-2015 10:40 AM
- « Previous
- Next »
