New Customer (from BT) - Cannot connect via RT-N66u router
- Re: New Customer (from BT) - Cannot connect via RT...
20-01-2017 9:20 AM
Setup: BT OpenReach Modem -> Asus RT-N66u router.
I have entered the correct username & password.
However, receiving 'incorrect username and/or password' message.
Is this a problem on the Plusnet side? Perhaps my account has not been correctly configured.
FYI - Phone line is fine
Re: New Customer (from BT) - Cannot connect via RT-N66u router
20-01-2017 9:25 AM
Good morning,
the activation had not triggered on our side, I've corrected this now, if you try to connect you should be able to authenticate now.
Let me know if you have any issues
20-01-2017 9:55 AM
HI
Thanks for the speedy reply.
I will try again tonight when I get home.
Many Thanks
20-01-2017 9:57 AM
Brilliant
I can see from our auth servers that you have been able to connect from our end
03-02-2017 10:57 AM
Hi
Sorry for the late reply.
Broadband is up and running.
Many thanks for your quick and friendly service
