New Customer - Upload Speed Fault?
- New Customer - Upload Speed Fault?
10-03-2016 10:21 AM
I them find out that the product is 40/2 and not 40/10 or 40/20... so i complain and 2 days ago i was promised that they would uncap the upload to allow what the line can handle..
well my line now syncs @
Downstream: 21.44 Mbps
Upstream: 4.903 Mbps
the 21.44 is around 10Mbps slower than with sky (I intend to replace the terrible One Hub) so i may see a difference then
but the upstream is only 1-2 mbps slower.. i can live with that for now, but what i cannot live with is the speed test ( i've used many, including the BT one) shows my upload at 1.7mbps constantly.. its like there is an artificial cap on the upload.
I should add that for one brief moment, when my router was connected to setup@plusdsl.net i actually got a speedtest of 4Mbps+
I am on the verge of cancelling under mis-selling, not to mention that the ASA has confirmed yesterday that Plusnets "totally unlimited" claims are wrong and they must stop using them!!
if this isn't sorted today then I am cancelling.
Re: New Customer - Upload Speed Fault?
10-03-2016 10:30 AM
10-03-2016 11:27 AM
Login to the Hub One, Go to troubleshooting, click Helpdesk and post that stats from there please.
10-03-2016 1:57 PM
1. Product name: Plusnet Hub
2. Serial number: +081441+NQ55005758
3. Firmware version: Software version 4.7.5.1.83.8.217.1.1 Last updated 08/03/16
4. Board version: Plusnet Hub One
5. DSL uptime: 0 days, 03:53:29
6. Data rate: 5021 / 21952
7. Maximum data rate: 5021 / 22338
8. Noise margin: 5.9 / 6.3
9. Line attenuation: 35.0 / 27.8
10. Signal attenuation: 35.3 / 23.5
11. Data sent/received: 242.2 MB / 3.4 GB
12. Broadband username: hazzatori@plusdsl.net
13. 2.4 GHz Wireless network/SSID: PLUSNET
14. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 300 Mb/s))
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: PLUSNET
18. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
22. MAC Address: 84:a4:23:0e:59:0a
23. Modulation: G.993.2 Annex B
24. Software variant: AA
25. Boot loader: 1.0.0
10-03-2016 1:59 PM
10-03-2016 2:11 PM
I am concerned that my IP Profile is at 21.5? shoudlnt that be at 40?
10-03-2016 2:18 PM
The IP Profile is about 0.967 of the sync speed
10-03-2016 2:36 PM
10-03-2016 2:40 PM
Your line will connect as fast as it can and then the IP Profile is set from the resulting speed
10-03-2016 3:31 PM
