New Customer- Router just showing orange light
marksp
I switched to Plusnet and the switch was completed on Tuesday, but my Plusnet router has not connected to the internet. I’ve phoned up and tried manually entering my username and password, tried through the test phone socket, done a factory reset, but all with no joy. The people on the phone were stumped, and are sending out a new router as a last hope, but reading on here when other people have this issue it’s not because of the router. I can’t wait the bank holiday weekend plus another few days before actually getting to the root of the problem, so was wondering if someone here can help?
Cheers, Mark
15 REPLIES 15
Fixes: 417
Re: New Customer- Router just showing orange light
Welcome to the forum.
I don't have a Hub One but I'm assuming that it's got a similar HCI  as my Smarthub 6. If you log into the router on 192.168.1.254 and look at the Status page, does it give an upstream and downstream sync rate?
It is possible for it to be connected to the Fibre Cabinet and is in sync but you get no Internet connection. If there's no sync then it's an infrastructure problem or despite assurances, the work has not been done (yes, this does happen). If it's in sync it's probably either Openreach have not got their settings right or Plusnet haven't activated your account correctly.
Please let us know how you get on.
Fixes: 1,483
if there is 'b' showing (glowing orange) on the hub one it's probably in sync.
marksp
Thanks, there’s no status page on the router’s screen for speeds etc. The Event log has a lot of ‘CWMP: session closed due to error: Could not resolve host’
Also the b is orange and not flashing.
Browni
Aspiring Hero
Fixes: 60
If it's a Hub One you'll find the speeds etc under the Troubleshooting->Helpdesk tab on the router's home page.
marksp
Thanks, the data is here. No upload or download, but a data rate of 9995/39993
Browni
Aspiring Hero
Fixes: 60
That ties in with what @Baldrick1 & @dvorak have said, you're synching fine to the cabinet but the setup username is preventing access to the internet.
marksp
Thanks, so it’s either Openreach or Plusnet not opening the account correctly. Any ideas where to go from here?
Fixes: 417
You have to go back to Plusnet using either phone or chat and give them this further information.
Browni
Aspiring Hero
Fixes: 60
Are you sure you're using the correct username & password?
The username is the one used to login to the member centre appended with @plusdsl.net and the password is the member centre password.
marksp
Yes, 100% sure. Also tried it with the original setup format and putting my details in manually
Fixes: 1,600
Hi Mark.
Sorry about the rocky start to your service.
Our tests aren't finding the cause of the problem, so I've contacted our suppliers to check the settings on their side and rebuild your circuit on their systems. This should take 24 hours.
If you're still unable to connect, we'd then need to arrange an engineer visit to investigate the Openreach network.
Sorry for any inconvenience this causes.
marksp
Thanks, I was literally just talking to tech support when you’re message popped up! I’ll let you know how it goes.
marksp
Just a quick update- an engineer came around today and we discovered the fault- the card in the cabinet needed resetting (I think, I may be completely wrong with this, but that's what it sounded like), so it was a fault with the cabinet after all, but it's fixed now. Thanks for everybody's help!
Browni
Aspiring Hero
Fixes: 60
Good to hear you're up and running!
