New Customer No Connection
- New Customer No Connection
on 07-03-2017 8:32 AM - last edited on 07-03-2017 11:57 AM by Strat
Hi there, my connection switched over to plusnet today and I got a text confirmation that it was good to go. I've plugged in the new router and it won't connect and router is solid orange. It's been this way for over an hour so far. I can see it is connected to the fibre OK from the advanced settings but just won't connect with username and password. Is there something you guys can check at your end? Username is [removed]. Thank you!
Moderator's note by Dick (Strat) Username removed from a public forum.
Re: New Customer No Connection
07-03-2017 10:41 AM - edited 07-03-2017 10:43 AM
The order on the line has completed however it can take a few hours in some cases for the account to trigger activation, I've done this manually now and you should be able to connect immediately
EDIT: I can see your router has now logged in successfully let me know if you have any questions about the service
