New Customer Fibre Broadband Speed Less than Half Estimate
ST1
Hi
I switched from BT Infinity 2 to Plusnet Unlimited Fibre Extra 15 days ago but I am getting less than half the download speed of my estimate for my line when I ordered.  I have tried different speed test sites and all report I've a download speed of approx. 20Mbps.  Here are the latest results from BT Wholesale Broadband Performance Test:
2nd Test Result using Plusnet user on router2nd Test Result using Plusnet user on router3rd Test Result using speedtest login on router3rd Test Result using speedtest login on router
Re: New Customer Fibre Broadband Speed Less than Half Estimate
There's every chance that you're on an ADSL2+ profile - have a look at your IP Profile. The BT one is 43.5 going by the screenshot. Your Current Line Speed should be just a little lower, but probably isn't.
Check yours here. (Login required)
Plusnet Staff
Plusnet Staff
Fixes: 159
Should be sorted now. Can you try a disconnect/reconnect.
 Chris Parr
 Plusnet Staff
ST1
Yeah looks like something is wrong with my Plusnet profile.
ST1
I'll give this a go when I'm back home this evening.
