New Connection
bake73
New Connection
Hello i just got connected and my profile is on 30/2 in the router(Hub One)when it should be 80/20. Will it get any faster or is that the max?
I'm not connected to the master socket but i will try this tomorrow.
Bernie
20 REPLIES 20
SpendLessTime
Fixes: 86
Re: New Connection
@bake73
Welcome to the forum.
I think you need to connect to the master socket to see if the extension is at fault. FTTC should be at full speed from day 1 if everything is working correctly.
By the way, the fastest Plusnet service is 80/20 not 80/40 as you wrote.
bake73
Re: New Connection
Yeah i meant 80/20 Embarrassed
I'll give it a try tomorrow as its a house i'm moving into.
I just thought the profile in the router would be 80/20 and i would understand if i was getting less as it could be a fault with the data extension.
This is what my profile says
Postcode:
Phone exchange:WIGAN
Estimated line speed:47Mb (This may vary between 35Mb and 47.9Mb) - Checked on 2016-07-25 01:26:46Current line speed:78 Mb
Thanks for the welcome Cool_smiley
SpendLessTime
Fixes: 86
Re: New Connection
The router info is taken from what it sees on the line, not some marketing speech speed which the upto 80/20 is really. So it can be at variance to expectations.
You may want to check what the BT speed estimate is given as at http://www.dslchecker.bt.com/adsl/ADSLChecker.Telephone?URL=&SP_NAME=a%20service%20provider&VERSION=...
And the Plusnet Line Speed may not be of much use, according to Bob Pullen, especially if your line is on the new network.
Of course, you may just have a fault.
Look forward to seeing the results of your testing.
MatthewWheeler
Fixes: 479
Re: New Connection
Our tests aren't showing any particular cause although you are on the 40/2 product which will be limiting your upload speeds.
I've placed a order to change this.
 Matthew Wheeler
bake73
Re: New Connection
Thanks any idea how long that will take?
I'm gonna have a look at the wiring later and try the master socket.
Cheers
MatthewWheeler
Fixes: 479
Re: New Connection
It'll complete tomorrow.
Is it not in the master socket at the moment?
 Matthew Wheeler
bake73
Re: New Connection
its on a data extesion from a mk3 master socket which is in the basement. Its an old cable that is already installed but i just wanted to try it before i start drilling and ripping things up Wink
SpendLessTime
Fixes: 86
Re: New Connection
So  not a fault, just Plusnet ordering the wrong product for you Huh
Sometimes I wonder why I bother when the supplier gets something so simple so wrong.
bake73
Re: New Connection
Tried it in the master socket and I get the same speeds.
Is there any chance my download speed will increase when I go on the 80/20 profile?
MatthewWheeler
Fixes: 479
Re: New Connection
As you're currently syncing at 30mbps I don't think so but we'll know for sure from tomorrow.
 Matthew Wheeler
bake73
Re: New Connection
Well i'm now getting 30/4 so slightly better.I was hoping to get at least the minimum i was told id get(35)
Can you just double check my profile please as i get the full 30/4 like im being capped.
bake73
Re: New Connection
I now have nearly 2 days uptime and its slowly creeping up. Im on 30829/4227 from 29/4 Tongue
Its a shame your lower package is 40/2 as id swap to that but i like the extra upload speed.
Cheers for the help Thumbs_Up
bake73
Re: New Connection
Hello I got this email the other day
When you signed up for Plusnet Broadband, we gave you an estimated line speed. Now that your broadband has now been active for 14 days, we thought we'd let you know the speed as it stands today, by way of comparison.
Estimated line speed 39.8Mbps to 53.6Mbps
Current line speed 29.4Mbps
Your current speed is lower than your original estimate, but don't worry. You should be able to improve things by following the tips in our broadband speed guide.
If that doesn't help, you may need to report a fault - please see our speed troubleshooting guide for help with this.
If you've got any questions about your service our Community Forums have loads of information and help available.
Ive tried all the suggestions and i've also run a new data extension with good cat5e cable to an rj11 data socket but still get the same speeds.
The connection feels very stable and probably the only times i've been disconnected is when i've been sorting the wiring and trying the master socket.
Anything else i can try or should i report a fault?
MatthewWheeler
Fixes: 479
Re: New Connection
I'd recommend raising a fault so we can look at getting a engineer out.
 Matthew Wheeler
