New Connection - Lower Speed than old connection
- New Connection - Lower Speed than old connection
30-03-2020 12:35 PM - edited 30-03-2020 12:39 PM
I moved over to Plusnet from sky last Thursday. For comparatives sake I performed a speed test with sky in the morning and plusnet in the evening and you can see from the I am now getting 2/3's of the download speed and half the upload. I am also seeing double the ping time - game quite frequently and this is important...
I have tried calling plusnet Friday and Sat no one was taking calls. I managed to speak with someone yesterday after waiting 45 mins who has advised they will get BT to look into this further with a resolution date of Wed.
You'll see the BTW checked for my line below and what my line should be capable of supporting.
I have previously had a line speed with Sky in Oct last year of this result 65.78up / 18.76down with a 10ms ping: https://beta.speedtest.net/result/8720262232 This is the speed my line can and should support and would like to get back to obtaining this speed.
Have I made a mistake moving to plusnet. Should I of stuck where I was? I hope this gets resolved, if it isn't am I within my rights if they cannot meet my minimum line speed (50mb) to leave without charge?
Why did I switch to plusnet.
29-03-2020 1:48 PM - edited 29-03-2020 2:05 PM
I had my broadband activated on Thursday. For comparatives sake I performed a speed test with sky in the morning and you can see from the attached I am now getting 2/3's of the download speed and half the upload. I am also seeing double the ping time - game quite frequently and this is important... I do hope that as part of the 10 day settling period this speed increases.
I will monitor over the next week and a half and persevere in the hope that this speed will settle and increase with stability, but if it does not I will be in touch.
I also attach the BT line checker, my downstream and upstream even on the low end should be 58.2 / 18. To note whilst with sky I had BT attend (before this Covid19) about 6 weeks ago and he replaced the whole line into the property up to the filtered faceplate.
Re: Why did I switch to plusnet.
30-03-2020 1:02 PM
Moderators Note
Posts released from spam filter and merged.
Re: New Connection - Lower Speed than old connection
31-03-2020 8:10 AM - edited 31-03-2020 8:22 AM
By way of an update, when I finally got through on Sunday to Plusnet they confirmed that I was on the correct package of 80/20 and raised a support ticket with BT Openreach.
I have just had a call from the BT Openreach engineer who has confirmed I am not on an 80/20 package and it appears I am on a 40/10 package. He did note that call centres in India are currently limited with the current situation and would probably need to raise this with a UK call centre.
I did explain that I am not getting the speeds I used to so just to double check the line between the cab and property in sheer desperation that this may assist to get back up to the speeds I used to.
Very disappointed that Plusnet tell me I am on the correct package (verbally) and BT OR engineer tells me my line is capped at the lower rate, this is schoolboy stuff... Or should be. Look at the stats, within 2/3Kbps off 40/10.
UP Speed Down Speed SNR Upstream SNR Downstream
9,997 (Kbps) 39,998 (Kbps) 15 (dB) 5 (dB)
Extract from my order email.
BT OR engineer is still working on it to see what can be done. I am getting well below my current speeds that I should be getting, my minimum guaranteed line speed should be 50mbps and have seen my line support up to 72mbps download.
