New 80/20 connection
Adamtemp
My Switch to Fibre has happened sync is 80/20 in hub one
Bt profile shows as 77.43 but in my high speed broadband page says 70.4 is this a stuck profile?
Very happy going from adsl at around 4mpbs to 66+ speedtests
GLOBALNET now part of madasafish now plusnet With The same isp since 1995 ( now all part of BT) now on a 21cn exchange wwstal 80/20 fttc
Plusnet Staff
Plusnet Staff
Fixes: 117
Re: New 80/20 connection
Hello there,
The router looks like it's in sync at a pretty perfect speed:
Downstream Speed 80.0 Mbps
Upstream Speed 20.0 Mbps
Connection Profile:Generic Speed 70400 No Time Out
I've maxed out your connection profile now. If you reboot your router or disconnect/reconnect your PPP session you'll be able to achieve a bit more speed.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
Adamtemp
Thanks will check when I get home in a bit watching football in the pub
Ok looking good http://www.thinkbroadband.com/speedtest/button/148198531371791892971-mini.png
Plusnet Staff
Plusnet Staff
Fixes: 117
Looking good, thanks for coming back to let us know. Thumbs Up
 Plusnet Staff
