New 80/20 connection
FIXED- Subscribe to RSS Feed
- Re: New 80/20 connection
17-12-2016 11:46 AM
My Switch to Fibre has happened sync is 80/20 in hub one
Bt profile shows as 77.43 but in my high speed broadband page says 70.4 is this a stuck profile?
Very happy going from adsl at around 4mpbs to 66+ speedtests
Fixed! Go to the fix.
17-12-2016 12:10 PM
Hello there,
The router looks like it's in sync at a pretty perfect speed:
Downstream Speed | 80.0 Mbps |
Upstream Speed | 20.0 Mbps |
Connection Profile:Generic Speed 70400 No Time Out
I've maxed out your connection profile now. If you reboot your router or disconnect/reconnect your PPP session you'll be able to achieve a bit more speed.
17-12-2016 1:41 PM - edited 17-12-2016 2:38 PM
Thanks will check when I get home in a bit watching football in the pub
Ok looking good http://www.thinkbroadband.com/speedtest/button/148198531371791892971-mini.png
17-12-2016 5:19 PM
