New 5g version appeared
FIXEDTopic Options
- Re: New 5g version appeared
30-11-2019 10:27 PM
Another version of the Plusnet network had appear on my wifi options with -5g at the end. Is this ligit? I can’t find any notifications about it so concerned it’s fake/ fraud attempt
Fixed! Go to the fix.
Message 1 of 3
(1,245 Views)
2 REPLIES 2
30-11-2019 10:29 PM
Have you called support at any point? I'd expect this to happen where we've helped separate your 2.4GHz and 5GHz Wi-Fi networks.
Message 2 of 3
(1,242 Views)
30-11-2019 10:34 PM
Ah yes, that’s it. I’d forgotten that I created a separate label for the 5ghz one. Thanks!
