turn on suggestions
Never mentioned
- Never mentioned
Never mentioned
Never mentioned
03-11-2014 3:22 PM
An efficient Openreach guy (actually from subcontractor the mighty M J Quinn & Co) arrived on time and carried out a trouble-free fibre conversion this a.m. He told me that raw speed here was now projected up in the 50s. Obviously, however, BTW still thinks I'm on ADSL, reporting performance as 2mb/s.
It looks as if, as experienced by so many others posting here, some PN intervention is needed. I don't recall this ever being pointed out. Why not? My understanding, when discussing the topic, was that the 7 to 10 day adjustment period could entail a downward adjustment for purposes of stability.
Re: Never mentioned
Re: Never mentioned
03-11-2014 4:03 PM
Re: Never mentioned
Re: Never mentioned
03-11-2014 4:03 PM
If this is what I think it is, it's been an issue with plusnet's automated systems for ages now. If you open the link below it'll show your current line speed, which I'm guessing is still incorrectly showing the ADSL speeds. Plusnet just need to quickly change this to your correct speed and you'll be running at full speed then. It should be changing automatically, but seems to need a little nudge more often than not.
If any plusnet staff could also pick up my request for the same thing that'd be great (added it to my house move ticket but nothing has been done with it yet)
Re: Never mentioned
Re: Never mentioned
03-11-2014 4:10 PM
Quote from: ArthurDent was that the 7 to 10 day adjustment period could entail a downward adjustment for purposes of stability.
there is no 7-10 day period for Fibre connections.
Re: Never mentioned
Re: Never mentioned
03-11-2014 4:30 PM
My new fibre connection went straight to 30Mb and there it has stayed
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
Re: Never mentioned
Re: Never mentioned
03-11-2014 5:05 PM
In fairness, Aaron has picked this up and corrected it promptly.
