Network probs..
patti
Network probs..
Just to clarify please.. are network problems causing my low speeds over the last few days and there is maintenance due tomorrow to troubleshoot them?
St3
Aspiring Champion
Fixes: 5
Re: Network probs..
patti
Re: Network probs..
Thanks, but although that link says maintenance it's not specific.. can anyone specify if it is for improvement of service etc., ?
rongtw
Fixes: 12
Re: Network probs..
WE can only hope Shocked they fix something .
Depends on what your problem is ?  and if you on old or new network ,, What does it say here http://usertools.plus.net/@gateway/
patti
Re: Network probs..
Hi Rongtw .. Not a promising start ..
Which gateway
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Issues topic in the Community forums will help us to diagnose the problem.
  • core2-hu0-18-0-0.colindale.ukcore.bt.net (62.172.103.16) 4.470 ms
Maybe they can do a bit of maintenance on this too.. Smiley
rongtw
Fixes: 12
Re: Network probs..
Is the New Network plenty of people are having extreme problems there Embarrassed
dnpark38
Re: Network probs..
Yes.
http://www.thinkbroadband.com/speedtest/button/1476198475230638155-mini.png
Fixes: 167
Re: Network probs..
What issues are you seeting Patti? Lets not jump to conclusions about what may be causing your issues as it may be something else, line fault, router, wifi etc.
 Chris Parr
 Plusnet Staff
rongtw
Fixes: 12
Re: Network probs..
whilst i agree it may not be linked to present problems , The lack of information from PN makes people think its related , i am sure you have read the massive post and seen what has been said
Fixes: 167
Re: Network probs..
I am aware of the thread, unfortunately just assuming every issue is related though just muddies the waters and means any investigation takes longer.
 Chris Parr
 Plusnet Staff
dnpark38
Re: Network probs..
What about some info. on the BIG problem please?
Fixes: 167
Re: Network probs..
This thread is for Patti's query, please keep it on topic.
 Chris Parr
 Plusnet Staff
patti
Re: Network probs..
Hi Chris, My speeds are erratic especially at weekends, (contention issues?) they will fall and rise dramatically  i.e as low as just over 2/3 meg to a high of 42 meg (never achieved the 55 meg so far) I can see the drop in upload perfectly well .. My main question is the instability of the speeds. Wired and unwired makes no difference. Why do they drop like a stone and then rise again? It's annoying to say the least and I have really noticed how slow everything is loading? That is the basis of my question regarding maintenance, and whether, as other have mentioned slow loading problems are being looked into?   Can you clarify what the maintenance is actually for please.. to fix what exactly? I know I am not alone in experiencing problems.
Fixes: 167
Re: Network probs..
The maintenance isn't to fix anything as far as I know, it's planned work to make back-end changes such as moving IPs between gateways and similar. We advise customers of the maintenance as sometimes we need to do some disconnections as part of it.
If the speeds are slower mainly in the evenings and weekends, it points to a congestion issue at the cab/exchange level quite often. I'd advise getting a fault reported to us at https://faults.plus.net
When the speeds are low can you run a BT Speedtest for me, ensuring you do the further diagnostics test after the first one completes. This stores the results on the supplier system and allows us to use this to report the fault.
 Chris Parr
 Plusnet Staff
patti
Re: Network probs..
Thanks Chris.. will do.
