Network problems
mishygraff
Network problems
I have just moved house and taken plusnet with me , broadband has just been activated this week. The router has the blue light but i keep getting messages on my other devices that a network error has occured and i am then unable to connect .
3 REPLIES 3
EmilyD
Fixes: 111
Re: Network problems
Hi @mishygraff,
I'm sorry to hear that you've been experiencing intermittent connection problems since moving to your new property. I've tested your line but the test hasn't picked up the cause of this problem from here:
GEA Test Detail
Circuit ID NA Service ID BBEUXXXXXXXX
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 10.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Bridge Tap Not Detected
Cross Talk Not Detected
Estimated Line Length In Metres 496.7
Upstream Rate Assessment Very Good
Customer Traffic Level Upstream and Downstream Traffic Detected
Technology VDSL
Profile Name 0.128M-40M Downstream, Interleaving Low - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2019-09-12T14:45:00
Parameters MIN MAX AVG
Down Stream Line Rate 40.0 Mbps 40.0 Mbps 40.0 Mbps
Up Stream Line Rate 9.9 Mbps 9.9 Mbps 9.9 Mbps
Up Time 900.0 Sec 900.0 Sec 900.0 Sec
Retrains 0.0 0.0 0.0
Current and Last 15 Minute Bin Performance
Parameters Last Traffic Count(Upto 15 mins) Current Traffic Count(Upto 15 mins)
Start Time Stamp 2019-09-13T13:15:46.382+01:00 2019-09-13T13:30:46.382+01:00
Ingress Code Violation 0 0
Egress Code Violation 0 0
Errored Seconds 0 0
Severely Errored Seconds 0 0
Unavailable Seconds 0 0
So that we can determine the best next steps towards a resolution for you, please can you confirm whether this issue is solely affecting wireless connections or if wired connections are affected too?
 Emily D
mishygraff
Hello Emily , yes I’m not connecting with a wired network on my pc either , well only intermittently.
MasterOfReality
Fixes: 57
Hi @mishygraff
I take that to mean you are connecting via WiFi.
WiFi is merely an optional alternate gateway to access the internet - a wired LAN (Ethernet) connection is always the primary connection method, and is the only one which can be guaranteed on both speed and stability.
There are a large number of potential reasons for slow speeds and sometimes these are difficult to track down.
It's likely the problem lies between your router and your devices which we don't have visibility of.
Unfortunately due to the way WiFi works there are a lot of environmental factors which can affect the wireless signal.
Have you tried changing the wireless channels? If not, then please follow the steps here .
Thanks,
MoR
 MoR
