Network access logging software
FoolishlyWise
Good evening all!
Examining my router logs this evening to see lots and lots of "[LAN access from remote]" entries that go to two IP addresses which are port-forwarded (since theyre two servers running different things).
Is there any kind of software that could possibly tell me, when installed on each of the two servers, what exactly is being accessed? For example, if its going to IIS etc.
Might be of use to note the two servers are running Windows Server 2012 Standard R2.
Cheers  Smiley
