Netgear N750 ok for Plusnet Fibre Broadband
- Netgear N750 ok for Plusnet Fibre Broadband
14-05-2015 12:51 PM
As per the title really, is the Netgear N750 ok to use if I upgrade to Plusnet Fibre. I'm guessing having one would mean I wouldn't need a separate Modem?
Message 1 of 2
(555 Views)
1 REPLY 1
Re: Netgear N750 ok for Plusnet Fibre Broadband
14-05-2015 2:00 PM
Edited for accuracy - ignore what this post said previously.
N750 isn't the model number, that refers to the speed and type of its wifi. We'd need the model number that probably starts with a letter D or WNDR to be sure. In summary though, if you want one that can be used as a standalone solution for Plusnet fibre with no seperate modem you need to make sure the router has got an integrated VDSL modem.
The only one I can see in the Netgear range that would be suitable is this one. Some others will work but only with a seperate modem, not on their own.
Message 2 of 2
(325 Views)
