Netgear DGND3700v1 VDSL working without openreach modem
- Netgear DGND3700v1 VDSL working without openreach ...
31-01-2015 11:36 AM
well I had a hell of a time to get my Netgear DGND3700v1 working directly with the built in modem. You can tell if you have a V1 as the serial number starts *2KB
I could not find any definitive list of settings anywhere so here goes. Hope it helps someone Follow at own risk etc as its not stock firmware or plusnet supplied hardware.
First Job was to update to this firmware to re-enable the VDSL modem on this router. It is there, just disabled in the stock firmware.
http://www.richud.com/wiki/DGND3700_V1_Transmission_Firmware
I then switched off auto update on the plusnet website under members centre/connection settings/automatic hardware setup. (not sure if required)
Basic Settings
Does your Internet connection require a login?
Yes (PPPoA/PPPoE)
Encapsulation
PPPoE(PPP over Ethernet)
Username and password same as you log into the main plusnet site
Service Name plusnet (not sure if required)
ADSL Settings
VC-BASED
VPI 0
VCI 38
DSL Mode Auto (Could probably be VDSL but I cant get it to stick)
Transfer Mode PTM (This was the killer & the last thing I tried!)
Network Settings
WAN VLAN ID 101
Enabled box ticked
xDSL Advanced Settings
DSL Modulation VDSL
And there you go, rest of settings are mostly stock.
I am very happy I got this working, I had it syncing for a long time before I changed to PTM on the off chance. All I read says this should be ATM...hey ho. Working now with just one box
Re: Netgear DGND3700v1 VDSL working without openreach modem
31-01-2015 2:41 PM
Quote I had it syncing for a long time before I changed to PTM on the off chance.
Confirmed its ATM for adsl/adsl2+ and PTM for VDSL
Well done and thanks for sharing, - another one to add to my list.
01-02-2015 8:50 PM
02-02-2015 3:50 PM
Was using an Openreach Modem along with my ASUS DSL-N66U Router to provide my Fibre and was only getting 39Meg. After reading your post and not realizing the DGND3700v1 was capable of VDSL2 I dug it out of the cupboard and gave your method a go and Voila it worked.
Speed is now at 47Meg which is an 8Meg increase. I suspect its because of the Router running a Broadcom chipset which in my opinion has always been the best to go for.
BEFORE: http://www.speedtest.net/my-result/4108146988
AFTER: http://www.speedtest.net/my-result/4110220473
Anyways, Thanks Again
02-02-2015 3:52 PM
02-02-2015 8:29 PM
02-02-2015 8:35 PM
02-02-2015 8:57 PM
02-02-2015 9:09 PM
02-02-2015 9:12 PM
02-02-2015 9:15 PM
However, the BT Openreach Profile 8c service is different. It uses G993.2 Annex B Plan A (aka Bandplan G.997) which is not compatible with, for example, the Profile 8a service from the North American telco Qwest.
BT Openreach is apparently using a second model of VDSL2 modem for its FTTC service.
The main model in use is the Huawei HG612, a device based on the Broadcom 6368 System on Chip.
02-02-2015 9:16 PM
02-02-2015 9:27 PM
02-02-2015 9:41 PM
http://community.plus.net/forum/index.php/topic,136287.0.html
02-02-2015 11:43 PM
