Netgear D7000
Netgear D7000
Hi has anyone setup this router with Plusnet fibre?
Got one coming tomorrow as my hub one always plays up and does not seem to get on that well with Amazon echo.
2 REPLIES 2
Fixes: 52
Re: Netgear D7000
Yes, easy to set up, just pick the ISP, chose the service - ADSL or VDSL and enter your PN username and password and away you should go - works well, plus you van get detailed DSL stats and run the DSLstats program should you want to.
Fixes: 31
Re: Netgear D7000
Hi @kirkyj,
Thank you for getting in touch.
You should be able to set up the router how @Mustrum has suggested however, if automation fails you can set up the router manually using the settings below.
Netgear Router Login:-
Web Address: http://routerlogin.net
Alternative: 192.168.1.1 or 192.168.0.1
Username: admin
Password: password
Username: Username@plusdsl.net
Password: Your account password
IP Address: Get dynamically from your ISP
DNS: Get dynamically from your ISP
ADSL:
Encapsulation Type: PPPoA (PPP over ATM)
Virtual Path Identifier (VPI): 0
Virtual Channel Identifier (VCI): 38
Multiplexing method: 'VC Based' or 'VCMUX' or 'VC-Multiplexing'
Fibre:
Encapsulation Type: PPPoE Always On
VLAN: Active
VLAN ID (802.1q): 101
VLAN ID (802.1p): 0
Thank you.
 Lewis G
 Infrastructure Operations Professional
