Netgear D6400
BobO
Netgear D6400
Having trouble connecting to internet using Netgear D6400.  Basically no internet connection.  In the wizard I entered the ISP login name and password (given by Plusnet) but would not work.  I now don't get the wizard page just the netgear setup page.  All connections are ok - line out from fibre optic to dsl line on netgear router.  switched off old bt modem and plusnet router.  Any help would be appreciated.
Champnet
Re: Netgear D6400
These are my d6400 settings, from advanced, setup, internet settings
you'll have to change the username for the full plusnet one.
Hope this helps
DM
http://www.champnet.co.uk/d6400/P1.jpg
http://www.champnet.co.uk/d6400/P2.jpg
gofaster
Re: Netgear D6400
Quote from: BobO
Did you enter the full login name including @plusdsl.net ?
e.g. myusername@plusdsl.net
Champnet
Re: Netgear D6400
Yes..............
MelRocks
Re: Netgear D6400
Hi there BobO,
I would ensure as suggested that your username is in the correct setup.
While we can't fully support third party hardware, we do have some basic settings to use via this link:
http://www.plus.net/support/broadband/hardware/broadband-connection-settings.shtml#fibreConnectionSe...
I hope this helps.
