Need some info
Zillawill
Need some info
Sorry if wrong place, but I've been trying to find some info about fibre rollout in my area.
On SamKnows the FTTC status is RFS date set : 30/09/2014 and on openreach website it says CS (Nov, 2014) however BTs broadband checker is only showing ADSL is that normal? and am I expecting too much by thinking I should have fibre sometime soon?  Tongue
Re: Need some info
It sounds like it should be available for you soon.
What result do you get form the BT checker https://www.btwholesale.com/includes/adsl/adsl.htm? If it gives your cabinet number when you enter your phone number then you're probably only a few months away from being able to order FTTC.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Zillawill
Re: Need some info
served by Cabinet 3
however it doesn't mention FTTC
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Need some info
Is there any information on http://www.superfast-openreach.co.uk/where-and-when ?
There is often news on this site, especially if you dig in to look at information surrounding your area as seen here: http://www.superfast-openreach.co.uk/rural-broadband/
Chris Pettitt
Cloud Environments Engineer
Zillawill
Re: Need some info
Like I said in first post, openreach website just says CS, and thanks for 2nd link apparently work was supposed to start in July but I haven't seen anything being done but you never know
adie:quote
Fixes: 68
Re: Need some info
Hi Zillawill,
It sounds like things are heading in the right direction.
The dates shown can be a little confusing but I'd keep checking every few weeks.
 Adam Walker
