Need some info
- Need some info
Need some info
27-11-2014 1:02 AM
Sorry if wrong place, but I've been trying to find some info about fibre rollout in my area.
On SamKnows the FTTC status is RFS date set : 30/09/2014 and on openreach website it says CS (Nov, 2014) however BTs broadband checker is only showing ADSL is that normal? and am I expecting too much by thinking I should have fibre sometime soon?
Message 1 of 6
(940 Views)
5 REPLIES 5
Re: Need some info
27-11-2014 1:21 AM
It sounds like it should be available for you soon.
What result do you get form the BT checker https://www.btwholesale.com/includes/adsl/adsl.htm? If it gives your cabinet number when you enter your phone number then you're probably only a few months away from being able to order FTTC.
Message 2 of 6
(560 Views)
Re: Need some info
27-11-2014 1:32 AM
served by Cabinet 3
however it doesn't mention FTTC
Message 3 of 6
(560 Views)
Re: Need some info
27-11-2014 2:29 AM
Is there any information on http://www.superfast-openreach.co.uk/where-and-when ?
There is often news on this site, especially if you dig in to look at information surrounding your area as seen here: http://www.superfast-openreach.co.uk/rural-broadband/
Message 4 of 6
(560 Views)
Re: Need some info
27-11-2014 6:40 AM
Like I said in first post, openreach website just says CS, and thanks for 2nd link apparently work was supposed to start in July but I haven't seen anything being done but you never know
adie:quote
adie:quote
Message 5 of 6
(560 Views)
Re: Need some info
27-11-2014 10:19 AM
Message 6 of 6
(560 Views)
