Need line checked
adyer88
Need line checked
Had a solid connection for 3 years synced at somewhere in the high 70s (forget exact figure) seems to have dtopped by about 10mb in the last week or so, could someone run a check see if any issuses present? Only change Ive made is from the OR router to the Hub One...
Cheers
Ash
Fixes: 187
Re: Need line checked
It looks like DLM has banded your line.
"0.128M-67M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off" Unfortunately we can't just reset this as that can only be done by a engineer if a physical fault is found and fixed.
It may remove itself overtime but I can't promise anything I'm afraid.
 Matthew Wheeler
adyer88
Thanks for the reply Matt.
Could i do anything this end to check if all is OK internally?
I know the speed drop isn't too much and it's still pretty high, just strange that its been stable for a few years.
Stats below if they show anything...
Data rate: 20000 / 67000
7. Maximum data rate: 26717 / 78321
8. Noise margin: 9.7 / 9.0
9. Line attenuation: 10.1 / 11.4
10. Signal attenuation: 10.0 / 11.5
Fixes: 162
Your line doesn't look bad but there would have been something (high errors, noise etc) that caused DLM to intervene. This will often remove itself and it's worth trying a single reboot every couple of days to resync the router.
 Chris Parr
 Plusnet Staff
