National Lottery Website.
- Re: National Lottery Website.
14-01-2016 11:29 AM
I know the NL site was having problems last weekend but I think that is sorted now.
I can access it on my iPad using the 4G network but not using the wireless connection through the router to the P/N network.
It's the same on all my PC's either wired or wireless.
All other websites work ok & I have rebooted the router several times with no avail.
My IP address is showing as in the UK as well.
I rang the NL & they say it could be an isp problem blocking the site?
Any thoughts please?
14-01-2016 11:38 AM
14-01-2016 11:43 AM
14-01-2016 11:49 AM
York.
14-01-2016 12:04 PM
No other website is affected including my bank login.
As I say, I have rebooted the router several times but something must be blocking it?
Have even changed my DNS servers with no avail.
Also tried different browsers.
14-01-2016 12:20 PM
14-01-2016 12:30 PM
14-01-2016 1:11 PM
This is the traceroute results to the NL site, not pretty!
dick:quote
14-01-2016 1:16 PM
See http://community.plus.net/forum/index.php/topic,130918.0.html
Dropping your connection and re-establishing may give you a different address that then works.
14-01-2016 1:18 PM
C:\Users\Jim>tracert www.national-lottery.co.uk
Tracing route to www.lb.national-lottery.co.uk [194.246.78.103]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms home.gateway.home.gateway [192.168.1.254]
2 12 ms 12 ms 11 ms lo0.10.Central10.ptn-bng02.plus.net [195.166.130
.190]
3 12 ms 12 ms 12 ms irb.10.PTW-CR01.plus.net [84.93.249.1]
4 12 ms 12 ms 12 ms linx-ge7-0-oscar.lon.router.colt.net [195.66.224
.49]
5 * * * Request timed out.
6 * * * Request timed out.
But trying www.lb.national-lottery.co.uk gives "The Connection Reset" and fails
14-01-2016 1:30 PM
14-01-2016 1:36 PM
National Lottery is a gambling site. Somewhere on your system access to gambling sites may be being denied.
If the problem affects all devices then you need to look at the router. is there an ant-gambling option that's been turned on ? Is your DNS acting as a filter, OpenDNS is good at this.
You also need to check the PlusNet firewall & Safeguard settings, these setting seem to change with or without your input.....................
DM
14-01-2016 1:51 PM
Had better point out that am using a TP Link 3600 fibre router & not a P/N one.
@Champnet, I haven't changed any router settings, not sure if there is a anti gambling option or not? I was using Google DNS & have changed back to the default P/N ones, it has made no difference.
As I already mentioned my safeguard isn't turned on, haven't checked the P/N firewall though.
Also I can access Bet 365 on my connection, another gambling site which probably eliminates any gambling site problems.
Edit, just checked & my P/N firewall is off.
14-01-2016 4:20 PM
Not been able to access it for years. I even opened a support ticket which said there was nothing wrong on PN's side so it was probably the NL website's host.
No idea. I just use my iphone with Wifi turned off when I need to go on that website.
But you'rte not mad, it definitely is an issue (for a small number of us).
14-01-2016 5:54 PM
Another traceroute using Windows CMD.
Stalls at hop 9, telehouse.ukcore.bt.net?
Routes to 2 other similar sites which work!
