My upload speed is only 2.5meg
banksy
Hi, I've just signed up to Plusnet after a seriously bad experience with talk talk!!
Anyway I was under the impression my upload speed was supposed to be between 8-10Mb.
Due to past bad experiences i took a screen shot at the beginning of the plusnet order. So what's going on?
Has anyone got the same problem, I do a lot of uploading to my online music library so this is an issue for me.
Ticked off
rongtw
Fixes: 12
Re: My upload speed is only 2.5meg
hi @banksy  what should you get when you put your phone number in here ?
https://www.dslchecker.bt.com/
banksy
Hi @rongtw, 20Mb i used to get 10 with talk talk? Crazy, Mislead as usual?!
Browni
Aspiring Hero
Fixes: 48
What speeds do you get when connected to the router via an ethernet cable?
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
banksy
Hi @Browni
Its the same 2.5mb
rongtw
Fixes: 12
i would try a BT speedtest , and the further diagnosis it will help  if you log a fault
http://speedtest.btwholesale.com/
Browni
Aspiring Hero
Fixes: 48
Something up somewhere.
Can you post a screenshot of your router stats with your personal info obscured please?
You can find them in the troubleshooting -> helpdesk tab at http://192.168.1.254
banksy
Hi @Browni i've no need to test because i had an open reach engineer round to check the line 4 weeks ago and he said there was no problems upload speed is 20Mb and download is around 66Mb so i'm guessing its plusnet not providing the correct speed?
Browni
Aspiring Hero
Fixes: 48
What I asked could have proved that but you obviously don't want to help yourself so I'm out.
RealAleMadrid
Aspiring Champion
Fixes: 17
You really are just guessing, people are trying to help but you seem to know better, I wouldn't believe anything an openreach engineer tells me and your line could have developed a fault in the last 4 weeks so there is always a need to test when something is wrong.Smiley
banksy
Hi @Brownie do you watch Dragons Den?
Thanks for the advise, Conclusion....It turned out to be Plusnet they said on activation a mistake had been made rendering my upload speed to just 2.5mb. This has now been corrected. I knew it had to be Plusnet due to the amount of checks I did and the openreach engineer did whilst I was with TalkTalk just a few weeks ago.
All the best Cool smiley
I'd Just like to add for anyone reading this that Plusnet are not easy to get hold of I tried three times but the waiting times were just too long. in the end I used the online chat although that is often down too? They advertise top customer service awards etc but its just a load of [-Censored-]!!!
Good luck. Ticked off
