My speed is below the minimum
- My speed is below the minimum
18-10-2019 12:47 PM
Re: My speed is below the minimum
18-10-2019 3:10 PM
18-10-2019 6:35 PM - edited 18-10-2019 6:36 PM
I've tested your line and your router is still getting a speed of 76.6mbps. There's also no error protection on although even it it was on there wouldn't be anything we'd be able to do as we've no control over DLM settings on a fibre line I'm afraid.
Looking at your connection this doesn't appear to have dropped once in 24 days, I'd recommend rebooting your router and if you're still seeing slow speeds, to investigate further please connect your computer/laptop to the router with an ethernet cable and run the BT Speedtester service at http://speedtest.btwholesale.com
You must ensure that you have no other programs running at the same time such as streaming, general browsing and the most common one is antivirus programs downloading updates in the background.
Once the initial result is completed please click Further Diagnostics then type your phone number in and click run diagnostic test. This will run a test and send the results to the BT server for investigation.
Once you have completed this, please report a fault to us at http://faults.plus.net letting us know over here once you've completed it and we'll make sure it is picked up as soon as possible.
