My ping has doubled when using XBOX
dw74
I'm wondering if anyone has any idea why my ping on XBOX ONE has just increased. Normally its around 17ms, but now its around 32ms when I test my ping.
Nothing has changed at my end, I'm still connected to the master socket and wired to the router. My ping to the router is 1ms so I know that's not the problem, I've disconnected everything and its still the same. My download/upload speeds are the same, its just my latency that has doubled in the last few days.
Any help would be appreciated,
Thanks.
9 REPLIES 9
LaurenB
Fixes: 131
Re: My ping has doubled when using XBOX
Hi there! Welcome to the Forums.
Can you do a Trace Route and post the results?
 Lauren Barry
dw74
Hi, thanks for the reply.
Where would you like me to do a trace route to? The ping is being reported on the Xbox within the network menu so I don't know where to run a trace route. I wish i knew the IP that it uses so I could get a better picture from my desktop. Do you know what address to use for Xbox live servers? Or is there another address you'd like me to try?
Thanks,
D
Fixes: 1,600
Ideally we'd like to run a traceroute to the Xbox servers but if you don't know the address, can you run a traceroute to pingbox1.thinkbroadband.com and/or bbc.co.uk?
dw74
OK.
Here's the traceroute for pingbox1.thinkbroadband.com (avg ping of 11ms):
traceroute to pingbox1.thinkbroadband.com (80.249.99.164), 64 hops max, 72 byte packets
1  dsldevice (192.168.1.254)  2.450 ms  1.212 ms  1.315 ms
2  * * *
3  * * *
4  be3-3100.pcn-ir01.plus.net (195.166.143.128)  10.448 ms  10.172 ms  9.847 ms
5  195.99.125.136 (195.99.125.136)  15.102 ms  11.199 ms  11.157 ms
6  peer6-hu0-1-0-1.telehouse.ukcore.bt.net (195.99.127.25)  10.613 ms  11.251 ms  11.712 ms
7  * * *
8  te2-1-9.star10g.bdr-rt3.thdo.ncuk.net (80.249.97.17)  14.599 ms  12.021 ms  11.556 ms
9  po4-31.core-rs2.thdo.ncuk.net (80.249.97.85)  11.302 ms  12.693 ms  11.055 ms
10  pingbox1.thinkbroadband.com (80.249.99.164)  11.604 ms  11.231 ms  11.118 ms
If I ping a website I'm getting about 10-11ms (which is usual I think) but using the xbox one Network diagnostics in the sytem settings menu's (I've tried it on two separate xbox's with same result) I'm getting a ping of 30-32ms to their servers. It may be a problem with their servers (with it being Christmas and potentially a whole loaf of new users accessign their servers) but I wanted to eliminate the possibility that it was at this end first.
dw74
the smiley in the traceroute is in fact an '8 )' so that iP should read:
195.166.143.128
jude-
My ping has gone from 17 to 28!
Fixes: 1,600
The latency looks fine throughout that traceroute.
It does appear that the issue lies with the Xbox servers.
@jude-
Is this causing you any issues?
dw74
Yes, I'm beginning to think that.
Thanks for taking the time to look.
Regards,
DW
Fixes: 1,600
No problems at all. Let us know if we can be of further assistance.
