My new fibre install
jockwav
Just wanted to check,my fibre will be installed next monday,the 1st of dec,when should i expect the new router to arrive. Smiley
https://www.flickr.com/photos/james_bingham/
22 REPLIES 22
Chris
Legend
Fixes: 169
Re: My new fibre install
The appointment is still showing as 01/12/2014 AM with no delays being flagged to us. The router would have been dispatch Weds/Thurs but I've just placed the order for that now.
jockwav
Thanks very much Chris. Smiley Grin
jockwav
New router arrived this morning,thank you,now just have to hope bt arrive as quick on monday. Smiley
adamwalker
Fixes: 221
Cheers for letting us know about the router jockwav.
Do let us know how things go after the weekend.
 Adam Walker
jockwav
The engineer turned up around lunchtime & found a line fault straight away,after about 4 hours all sorted & very happy,excellent BT engineer, Smiley Cheesy
What do i do with old router?.
jockwav
What do i do with the old PN router?. Smiley
tijara33
Fixes: 6
Just keep it, they won't want it back, it's not worth the postage. I have 3 at the moment.
jockwav
I just want to make sure before i get rid of it as it is no good to me anymore. Smiley
jockwav
The only thing i don,t like about the fibre install is BT have to fit another box like a router which is another thing i have to plug into the mains,more cables.
As the engineer said PN are the only ones they have to do this with,why is that?,can,t PN supply more up to date routers with all that built in?. Shocked
Chris
Legend
Fixes: 169
At the moment we only have routers where the modem is used alongside them, sorry!
jockwav
Ok no problem Chris,just wondered,so it would be possible to get an all in one. Smiley
davidwalker900
there is a few routers have modem bulit in for fibre connections you need one that does the speeds do google seach on with routers before you buy
jockwav
Cheers for that,i probably won,t rush to buy one just now,but it,s good to know. Smiley
davidwalker900
Jockwav can you change the size of that speed test on your sign thing it is too big it is a forum rule and you welcome on that tip i given you
