My fibre connection is down
Fixes: 71
Is there anything going on at my exchange? My fibre connection has gone down at home - the light on the homehub is orange and the 'b' symbol is flashing red.
Have tried logging into the HubOne and checking the connection, no luck.
Have also done a hard reset by holding the reset switch down but its not coming back online.
Could someone in the CS team take a look for me please?
Fixes: 31
Re: My fibre connection is down
Hey @jaread83 I hope you're not expecting favours here! Wink
Fixes: 71
course not, just doing what any other normal customer would do Smiley
Fixes: 385
Our tests are picking up a fault on the Openreach network which I've raised now.
Fingers crossed it's a quick fix but we should know more within 24-72 hours.
I've created a fault ticket on your account to my teams workflow, so I'll follow up on Tuesday at the latest.
Fixes: 71
Thanks for taking the time to have a quick look @Gandalf Smiley I will wait and be patient till then!
Fixes: 71
I have had 2 BT engineers over. The first said that the last engineer (on the day the internet went down at my house) to work on the cab and pole outside my house had disconnected mine to provide someone else a connection, leaving my connection dangling in the wind and not connected to anything... with no spare connections that could be used apparently... thats not very good. It was getting dark so they said they were passing it to another engineer to come out on Sunday, leaving me without internet for the weekend Sad
So on Sunday, new engineer has a look and disputes what was said by the last engineer, tested my line and it has a dial tone and detects the speed of my line. Okay, that sounds good but my internet still isn't working and the HubOne is flashing orange with a red broadband light. Engineer said that he will reset my line at the cabinet and it should come back on... if not I needed to call tech support. He never returned to check. So now there is yet another appointment booked for Thursday where another BT engineer is going to check the wiring within my property and the street.
@Gandalf, I have acquired a secondary router, micro filter and telephone cable from the office. I really don't want to incur a charge if they find that one of my wires is faulty. If I find that replacing one of the wires going to my router fixes the issue (or the router itself), is it possible to cancel the appointment ASAP so they don't charge me £65 for something I could have fixed myself (cable, microfilter or router replacement)? I am going to try it out tonight and will report back if there are any issues.
Fixes: 385
I'm sorry that two engineers haven't managed to fix the issue.
Yeah we should be able to cancel the visit if we know by tomorrow.
If your new equipment doesn't help and assuming you've tried the test socket it's probably best to leave the engineer appointment booked in as from what I can see we've got a SFI (Special Faults Investigation) visit arranged.
Fixes: 71
New router, phone cable and micro filter didn't make any difference unfortunately Sad
I tried looking at the test socket but once you take the faceplate off there isn't another port.. just an opaque cover on the left that can't be removed.
I guess its best to let the BT engineer sort it out. I hope they don't charge me! This was working fine up until a BT engineer was doing a new provide to another house on my street!
Fixes: 385
Fingers crossed it's a quick fix on Thursday.
Browni
Aspiring Hero
Fixes: 45
This thread has already been marked as fixed.
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
I must have been really bad in a previous life as this was my 3rd ISP in a row that used lithium.
Now you're stuck with me because my new ISP doesn't run a forum Cheesy
Fixes: 385
I think Jack was a bit hasty with the fix button. Smiley
Fixes: 71
I marked as fixed as my initial question about my conection being down was answered.
@Gandalf, I tried plugging into the master socket behind the faceplate but still no luck I'm afraid.
Fixes: 196
@jaread83
I've taken the liberty to remove the fix as, well, it ain't fixed yet Wink
Forum Moderator and Customer
Fixes: 71
Fair enough Smiley let's see if BT can fix it on Thursday!
Fixes: 385
Keep me posted!
