My download speed has dropped
- Re: My download speed has dropped
21-01-2016 10:52 AM
I have been getting a fairly stable download of 36 Mbps since I switched to fibre. Over the last few days this has dropped to 26 - 28. Is there a fault? BT test result is attached.
Message 1 of 9
(2,128 Views)
8 REPLIES 8
21-01-2016 2:31 PM
I've just been running some tests which didn't highlight any problems.
Just to help us narrow things down can you try connecting to the router using a network cable and try testing the speeds again using this site? http://speedtest.btwholesale.com/
Message 2 of 9
(778 Views)
21-01-2016 7:13 PM
Here are the test results with ethernet connection
Message 3 of 9
(778 Views)
22-01-2016 1:58 PM
Speed seems stable at 28 ish like it has been capped. Here are todays test results from the BT site. Is anybody dealing with this problem?
Message 4 of 9
(778 Views)
22-01-2016 11:45 PM
Quote from: 2010dsc I have been getting a fairly stable download of 36 Mbps since I switched to fibre. Over the last few days this has dropped to 26 - 28. Is there a fault? BT test result is attached.
I'm having exact same issues. I joined plusnet earlier this month and was getting 36+Mbps, it dropped to around 32 on the 18th Jan and now seems capped at 28Mbps.
My Estimated line speed is 35-51Mb.
Just ran a bt test and it looks like my Ip profile has been reset to 30Mbps, sorry I'm new to all this how do you get that raised back up?
Message 5 of 9
(778 Views)
23-01-2016 12:23 PM
Quote I'm having exact same issues. I joined plusnet earlier this month and was getting 36+Mbps, it dropped to around 32 on the 18th Jan and now seems capped at 28Mbps.
I don't know how we get the speed back that we are paying for. I can't even get anybody from plusnet to reply. I would try online chat but it's always unavailable. The quickest way to get a better service might be to talk to Sky or BT.
Message 6 of 9
(778 Views)
28-01-2016 2:34 PM
It is 7 days since I first told you about the speed reduction on my account. My speed is still 28Mbps and I am still waiting for someone to sort it out. At least tell me if you are going to do something or not.
Message 7 of 9
(778 Views)
28-01-2016 2:41 PM
Message 8 of 9
(778 Views)
28-01-2016 9:43 PM
The short answer is No. I had to be away from the computer, and I have only just returned. I have tested again and the speed is now 23.88. I have been constantly testing when I have time and haven't recorded a speed over 29. I've done the tests on wifi and ethernet and they are both the same.
Message 9 of 9
(778 Views)
