My Ping and I
- My Ping and I
Re: My Ping and I
24-04-2019 3:33 PM
As requested, I ran it 3 times. Please see attached
Re: My Ping and I
24-04-2019 4:21 PM
Re: My Ping and I
26-04-2019 7:41 PM
Yea... no better...
see attached
Re: My Ping and I
26-04-2019 8:11 PM - edited 26-04-2019 8:13 PM
Boo more like!!
But I don't get it. Lets say this affected you, it was recently fixed:
(doesn't mean it did, just if)
It appears I was misinformed and you were in fact connected to the impacted data centre. The improvements we made were from around lunchtime on the 18th of April, if this is about the time that your services improved, it's likely this was the cause
The above was aimed at me and my issues appear to have been fixed.
And I'm still on a dynamic IP.
I'm at a loss as to why you're seeing this still:(
edit. I posted earlier (or the other day, can't remember) but I did state that I wonder if the PNH1 was introducing the loss within itself. I'm not currently using either of my PNH1's..... hmm, is this possible?
Re: My Ping and I
26-04-2019 8:28 PM
Hi DS
Glad your issue is resolved!
This is a brand new router (<1week old) so I'd like to believe that isn't the issue if that's what you are referring to with PNH1?
Intrigued as to what Plusnet now suggest...? Hopefully they check that it isn't same issue you mentioned above before coming back with their next plan of action.
Re: My Ping and I
26-04-2019 8:55 PM
I'm hoping it fixed, thus far it does look okay....
I've missed something, what router you running at the mo?
(assume the last traceroute was direct, no PLA's, no why-fi - subtle hint at a certain router there;))
Re: My Ping and I
26-04-2019 9:03 PM
I couldn't find any replacement power cables etc to use after PN suggested I attempt replacing them. So plusnet sent out a new router this week. I posted before that performance had improved (definitely not even close to perfect) but wanted to wait until prime time to make sure it wasn't a load issue as I was testing in the middle of a work day. When testing later 6pm+ the result were exactly the same as the old PN router. No change.
I just ran tracert bbc.co.uk in command prompt, if that is direct then yes lol. Also not sure what a PLA is but that is the method I used to ping trace.
Re: My Ping and I
26-04-2019 10:37 PM
Ah, okay. So they sent a new Plusnet Hub One out?
If that's giving the same results during peak time then surely this indicates a congestion issue....?
(unless you're connecting via wifi only)
Nah, by direct I meant with one ethernet cable, from the router straight to the device you're using for the traceroutes.
(with nothing else using the connection)
PLA = powerline adapters (aka ethernet plugs)
Re: My Ping and I
27-04-2019 6:10 PM
Yep all tests were done over ethernet (multiple different cables to be sure). Yes I think it is the Plusnet Hub One.
My internet seems to drop out at night and in the early mornings for 30mins quite regularly too, which is super... Really losing patience with this now.
Re: My Ping and I
28-04-2019 2:37 PM
I was half expecting to see someone from Plusnet popping on here with some further assistance....
Is there anything showing on the routers event log?
If the drops are for that length of time, plus around those times, then I'm wondering if this is a REIN issue, which if it is, will be a right pig to find and sort out.
Re: My Ping and I
28-04-2019 2:41 PM
Thanks for the update @jbligh87
I can see that @MatthewWheeler has taken ownership of this one for you, so I'll ask him to drop you a line tomorrow when he's back in the office.
In the interim, do you happen to have a 3rd party router to hand that would rule out/confirm your theory that the Hub One is at fault?
Best wishes
Dave
Re: My Ping and I
30-04-2019 1:07 PM
Re: My Ping and I
30-04-2019 1:49 PM
Re: My Ping and I
30-04-2019 5:23 PM
Re: My Ping and I
30-04-2019 6:13 PM
Sorry to hear that you're still having issues.
I'm afraid at this point we're very limited in what we can do going forward as the entire line has been checked and multiple routers tried although they are all from ourselves.
I've removed the static IP from your account and dropped your connection as we believe the wider issue affecting this is resolved.
Can you see how you get on being connected on a dynamic IP?
