My IP profile
jamman
My IP profile
My Plusnet profile is about 6MB lower than my BT profile (74mb) for the last 24 hours, could you please give it a nudge?
Fixes: 167
Re: My IP profile
Your downstream line rate seems to have fluctuated a bit over the last couple of weeks, I've nudged the profile to match the current sync.
Down Stream Line Rate  70.4 Mbps  76.8 Mbps  71.0 Mbps
 Chris Parr
 Plusnet Staff
jamman
Re: My IP profile
I am not seeing the IP profile change reflected in speed tests it is still the same as before. Currently my line sync is 76831, my BT IP profile is 74.37 and my plusnet IP profile is 76.8 but as I said I am still getting around 65mb on any speed test I do which was what I got before the profile change. Any idea whats up?
Fixes: 167
Re: My IP profile
Have you tried a single disconnect/reconnect from within the router settings?
 Chris Parr
 Plusnet Staff
jamman
Re: My IP profile
that seems to have fixed it thanks Smiley
Fixes: 238
Re: My IP profile
Glad to hear it's fixed.
Let us know if you have any further issues.
 Matthew Wheeler
bustermissy1961
Re: My IP profile
can you do the same for me Matthew because for some reason my IP Profile has gone from 77.44 Mbps to 66.78 Mbps.
Fixes: 238
Re: My IP profile
@bustermissy1961
The profile that we increased for the original poster was our profile not the BT Profile. We have no control over the BT profile.
 Matthew Wheeler
bustermissy1961
Re: My IP profile
Can you find out why BT has decreased my profile by 11Mbps without and reason.
Fixes: 387
Re: My IP profile
mod:note
bustermissy1961 you already have your own thread, can you keep relevant posts to that please.
My Broadband Ping - PN-Fibre
