My Fibre Connection
- Re: My Fibre Connection
My Fibre Connection
18-01-2016 10:21 AM
My connection speed is usually around over 37 mbps down & just over 7 mbps up.
It dropped way down last night to around 11 mbps down,so i did a gateway hop & it started to come back up again.
My IP is now 80.i use internet radio because our village is in a dip with big hills around & this morning it is constantly losing the radio.
Before last night my radio has been solid,what is going on,can someone look at this for me.
http://www.thinkbroadband.com/ping/share/852cd2bd3a5fc1da5e362d6a6ce57bfb.html
18-01-2016 11:54 AM
Are you having any other issues with your connection? What kind of speeds are you getting?
18-01-2016 1:52 PM
http://beta.speedtest.net/result/5007322155
18-01-2016 2:42 PM
18-01-2016 2:46 PM
18-01-2016 2:54 PM
My actual speed though is:
<a href="http://www.broadbandspeedchecker.co.uk"><img src="http://www.speedcheckerapi.com/Images/229446357.jpg"></a><br />Try <a href="http://www.broadbandspeedchecker.co.uk">internet speed test</a>
18-01-2016 3:03 PM
mav:quote.
18-01-2016 3:05 PM
So how did my IP come up as 146.last night.
Quote from: Chris No
18-01-2016 3:17 PM
Quote from: jockwav Can you start a new thread please.
Quote from: DJColinCook I've been having the exact same problem and after the 23 minute wait to get through to Support I also got told that my connection is synced at 40mb/s
I did (no reply yet) - but I cant see a problem with letting this user know that his problem isnt unique but is happening to others
In fact there are several threads along a similar vein all with similar timescales. Perhaps Plusnet Support might see them all and decide there is an issue to investigate
18-01-2016 3:19 PM
mav:quote
18-01-2016 4:52 PM
Quote from: jockwav So how did my IP come up as 146.last night.
We have a lot of different IP ranges, 146. is just one of them.
