My FTTC speed halved Since Jan 2013 Openreach/Plus.net wont tell me why!
- Re: My FTTC speed halved Since Jan 2013 Openreach/...
01-11-2014 8:02 PM
Now PN are saying that Openreach will not tell them why my speed and estimated speed has dropped so much and there is nothing further they can do, I must just accept this without any explanation. I feel this is extremely unsatisfactory.
Openreach have also handled my case very badly over the last 22 months
- five engineers failing to show up when scheduled
- wrong engineers being sent out (3 times I was sent an overhead linesman when Openreach had said the fault was underground), a non-broadband trained engineer was sent on one occasion,
- an engineer who had visited previously told me that changing pairs was not the answer to my problem and that he would return the following day with a colleague to test out sections of the cable and trace the fault, but he just turned up whilst I was at work and changed pairs.
- a REIN engineer visited fitted a filter to my master socket then said he was going to follow the line back to the cabinet and check for electrical interference, but just got in his van and drove off to his next job
- Openreach have told plusnet that my connection is slow as I am 1.3km from the cabinet when in fact an engineer has measured my line at 650 meters from the cabinet
- Openreach agreed to move me to a different pole which is connected to a different cabinet, they sent out an engineer to test the spare capacity on the pole, the engineer spoke to my partner and said that Openreach would not move me as the pole is connected to a different cabinet and drove off, the engineer just reported back to openreach there was no usable connections on the pole
- Openreach are now saying that they will not move me to the other pole as the wire would interfere with electrical cables, my drop wire is currently carried safetly under the electrical cables buy the use of a bracket which is attached to the electrical pole outside my house, the same method could easily be used to re-route my drop cable to the other pole.
- PlusNet have run many test which often pass but often fail (GEA Test detail says Circuit performance appears unstable due to mean time between errors issues. Continue submitting trouble report)
I have asked PN to ask plusnet to explain all of the above and why they can't use a bracket to re-route my dropwire but apparently Openreach have told plusnet that they have wasted too much time and money on me and have told them to stop submitting any more requests. They will not answer any of my questions that I have asked over the last 22 months. They also do not appreciate that I have taken over 2 weeks off work waiting for their engineers.
I feel that I have been let down badly by Openreach and now plusnet, plusnet have told me I am free to leave my contract, but I am in a non cable area and therefore am totally reliant on my BT line to give me broadband.
Please could someone let me know where I can go to take this further, I cannot believe a company can treat someone like this without explanation
Re: My FTTC speed halved Since Jan 2013 Openreach/Plus.net wont tell me why!
01-11-2014 10:15 PM
https://www.tio.com.au/consumers/types-of-complaints-we-handle
02-11-2014 10:10 AM
dick:quote
02-11-2014 5:16 PM
Quote from: cwaite PlusNet have run many test which often pass but often fail (GEA Test detail says Circuit performance appears unstable due to mean time between errors issues. Continue submitting trouble report)
This means your line is erroring a lot - which in turn means DLM will be reducing your sync speed to provide stability.
Can you post your speed estimates from here http://www.dslchecker.bt.com/ ?
02-11-2014 7:31 PM
dick:quote
03-11-2014 12:15 AM
Don't waste any more time with plusnet if they say your free to leave*.
http://aa.net.uk/broadband-trial.html
Yes they are that good.
*(You can keep your phone with plusnet if you've paided for the LRS)
03-11-2014 9:54 AM
If the BTOR infrastructure is decrepit and / or there is significant cross talk on the local circuits then NO ISP is going to make a jot of difference. The manifestation of cross talk as the population of fibre installation on a cabinet rises is the most prevalent cause of speed estimates being reduced.
Your comment is made in a vacuum of facts and is therefore unhelpful.
03-11-2014 1:48 PM
I’m sorry to see that you haven’t had the speeds that you initially received. I’ve looked through the history of your account and it seems that we have done everything possible to try to improve the speeds for you. It seems, looking at your estimate, that BT now believe that you and others cannot get the speeds initially estimated hence the slower estimates that have now been provided.
We are in a position that no remote work can be done to improve settings. On ADSL, we can change SNR’s or add/remove interleaving settings all of which can have dome impact on the connection in one way or another. Unfortunately with fibre we can only arrange further engineers for you. As you state, this has been done multiple times now and doing so again would seems to be wasting your time.
Openreach will not change you onto a different pole without a very good reason. As you currently have a 19Mbit sync rate, which is within the range of the current estimates, they won’t consider this however much we request that this is done for you.
One of my colleagues in our faults team has escalated the case as far as he could for you. Even with this input, we have been unable to progress the matter to your satisfaction for which I am sorry.
I appreciate you’ve had problems for a long time but we usually wait until the faults is resolved before we look into any goodwill gesture (such as a lack of engineer, or the wrong kind of engineer visiting are things). As it looks like we won’t get to resolve this to your satisfaction, I’m happy to discuss this further on your account.
Tony
03-11-2014 2:32 PM
Your best option now is to talk to your neighbours and see what is their experience. Then discuss the collective (but individual) submission of mass complaints to Ofcom over BTOR service provision. Unfortunately there is little pressure anyone can apply against this failing monopoly.
I would suspect that all ISP providers in your location are at the same level of deadlock with BTOR. It us down to the ISP to progress the issue with their supplier on behalf of the end customer, however if BTOR say "No" then there us no recourse other than Ofcom. Understandably some ISP CEOs are reluctant to report another part of their parent group to the industry watch dog. If the ISPs will not raise the issue with Ofcom then the local residents must do so. In the past similar people power has brought about resolutions where the actions of ISPs and their CEOs has not.
Good luck,
Kevin
03-11-2014 2:37 PM
Their bt account's mananger would not have stood for this.
The Cwaite has lots of options and aaisp is one of them.
03-11-2014 5:41 PM
03-11-2014 6:02 PM
There are multiple options to approach the issue. Its just comes down to what cwaite wants at the end of the day and if its worth the time, stress and cost.
Its just unfortunate openreach make things so difficult and from personal experience plusnet for some reason don't seem to be as assertive with openreach as other isp's.
03-11-2014 9:58 PM
My neighbours have stuck with ADSL as they have been put off moving to fibre from what I have told them of my experience, so not much chance of people power in this instance.
Obviously it's too much for me to expect the speed I had when I signed up, but my main gripe is that Openreach/Plusnet will not explain ANY of the points I have asked about their engineers lack of actions they also will not listen to my suggestion on re-routing my drop wire (they had already agreed to move me)
04-11-2014 9:02 AM
https://www.dropbox.com/sh/z28hx3pa66g007u/AADb3LhIrEzpiwLxTHRLwBEZa?dl=0
04-11-2014 10:09 AM
Having difficulty opening that - are you able to extract them and post them on here?
