My Broadband speed seems to be getting lower
FIXED- Subscribe to RSS Feed
- Re: My Broadband speed seems to be getting lower
08-03-2019 10:07 PM - edited 08-03-2019 10:18 PM
I've noticed that when I had my internet installed about 6 years ago now it started out as a 52 download and a 11 upload now its more like 44 down and 6 up I was wondering if there any staff about that maybe you could run a line check for me because it seems a little weird to me
Fixed! Go to the fix.
08-03-2019 10:44 PM
Welcome to the forums
Plusnet offered 80/20, 55/10 and 40/10 depending on when you joined them and if you've renewed your contract.
80/20 is still available
55/10 has been reduced to 40/10, though some customers complained and some have been able to retain 55/10
40/10 was reduced to 40/2, but customers weren't too happy about this, so Plusnet went back to 40/10
If you've renewed and didn't spot the 55/10 reducing to 40/10 then depending on when you renewed, you're probably stuck with it.
You could also be having speed issues too, but it might be worth looking at when you last renewed and whether you have an email from Plusnet stating they were reducing you to a lower speed package.
08-03-2019 11:11 PM
@DS 55/10 was never a product offered by PN.
They did use the 80/20 service to provide either a 76/20 or 38/20 product until the bean counters noticed!
38/20 customers were told they would be moved to a 55/10 product about 3/4 years ago, seems that project still has not completed!
At the same time, new customers were offered 76/20 or 38/2, the latter proving very unpopular and so in line with other ISP's, not least Talk Talk were moved to 38/10.
It seems to me, the OP was on, and probably still is on the extra product, but unless they share some meaningful facts/sync speeds its all a bit subjective.
08-03-2019 11:29 PM
I could've sworn I'd read somewhere on here that someone on PN actually started to get the 55/10 deal.
Anyhoo, thanks for the correction
09-03-2019 1:51 PM - edited 09-03-2019 1:52 PM
Hi @SteveWilliams61,
Thank you for getting in touch. I'm sorry to hear that your speed has dropped.
I can see that you're provisioned on the 80/20 fibre but, due to the length of the line, your estimated download speed is 40.4-59.2mbps.
I've tested your line and it's currently syncing at 49.7mbps, however the connection profile on your account is set to 45mbps. As you have a static IP, this connection profile is restricting your throughput speed to a maximum of 45mbps. If you reboot your router you should find that this increases.
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 49.7 Mbps | ||||
Upstream Speed | 6.8 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 702.0 | ||||
Upstream Rate Assessment | Low | ||||
Downstream Rate Assessment | Reasonable | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-80M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-02-24T13:45:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 47.1 Mbps | 51.7 Mbps | 51.4 Mbps |
Up Stream Line Rate | 6.3 Mbps | 7.9 Mbps | 7.8 Mbps |
Up Time | 578.0 Sec | 900.0 Sec | 899.5 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-03-09T13:18:52.213+00:00 | 2019-03-09T13:33:52.213+00:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
09-03-2019 1:58 PM
Thank you so much
