Much lower download speed following 'upgrade' to 55/10
FIXED- Subscribe to RSS Feed
- Re: Much lower download speed following 'upgrade' ...
13-08-2016 3:24 PM
Hi
Before 'upgrade' was regularly getting 38/19.
Now I'm on 55/10, regularly getting less than 20 download.
When first 'upgraded' speed was fine so will someone please let me know if this temporary or is there a network problem.
Thanks for your help.
Fixed! Go to the fix.
Re: Much lower download speed following 'upgrade' to 55/10
14-08-2016 10:15 AM
Checked speed again today and appear to be 'capped' at 20 download.
Can someone at Plusnet please look into this for me.
15-08-2016 11:46 AM
The package is called 55/10 for a reason. The download should be capped at 10Mb/s. If you're seeing anything higher than that it's a fault. You should probably keep quiet about it for now but eventually PN are going to notice
15-08-2016 12:24 PM
You are just so wrong Andrue.
The 10 is for UPSTREAM and the 55 is for DOWNSTREAM so getting just 20Mbps down is not good. @SoFarSoGood should still be able to get 38Mbps down, not less than 20!
15-08-2016 1:07 PM
I can't see anything that should be capping you as low as 20Mbps down, however I've pumped the profile on our side up from 40 to 55 as that was a little low.
Could you try a disconnect and reconnect and see if that's any higher now please.
15-08-2016 3:44 PM
Hi HarryB
Thanks, now back to normal (as it was when I was first 'upgraded') at around 51/9.
Any idea why it 'slipped down' from 55 to 40?
Many thanks for your help.
15-08-2016 3:51 PM
Maybe that wasn't actually affecting you, as it had never actually been at 55.
It also looks like your connection is still showing ongoing for 13 days, so the change I made earlier would have had no affect at this point.
15-08-2016 4:03 PM
Hi HarryB
I Tried before rebooting and now rebooted and tried again and same as before rebooting i.e around 51/9.
Whatever you did has worked so far.
Thanks again for your help.
15-08-2016 4:11 PM - edited 15-08-2016 4:14 PM
Indeed, yes. For some reason I thought you were talking about the upstream. I should have realised when it didn't seem to make sense.
Sorry.
