Moved to Plusnet. Speed changed 31 to 13mbps
- Moved to Plusnet. Speed changed 31 to 13mbps
18-09-2018 10:32 AM - edited 18-09-2018 12:25 PM
Hello
I moved from BT to john lewis supplied by plusnet
My speeds were 31 mbps first few days but the router was hard reset as advised by technical team due to reliability issues. These are now sorted but I am stuck on lower speeds.
I requested unbanding which helped a bit increasing the speeds from 11 to 14mbps. My guaranteed speed is around 18 and I was getting 26-31 before.
Many thanks in advance. Any help would be appreciated.
Message 1 of 3
(575 Views)
2 REPLIES 2
Re: Moved to Plusnet and lost 11Mbps over night
18-09-2018 10:33 AM
I have attached a screenshot with router stats as I don't understand if they reflect where the problem is. Thanks again.
Message 2 of 3
(574 Views)
Re: Moved to Plusnet. Speed changed 31 to 13mbps
18-09-2018 5:33 PM
Message 3 of 3
(506 Views)
