Moved from Fibre Unlimited to Fibre Unlimited Extra. When will I see a difference?
FIXED- Subscribe to RSS Feed
- Moved from Fibre Unlimited to Fibre Unlimited Extr...
14-12-2020 7:16 PM
I restarted the Home Hub and there was no change. Just wondering when I should expect to see some change.
Many thanks
David
Fixed! Go to the fix.
Re: Moved from Fibre Unlimited to Fibre Unlimited Extra. When will I see a difference?
14-12-2020 7:36 PM
Judging by your speeds at 27meg down. It doesn't look like you could get any higher speeds, that's why I asked what the maximum attainable rates are.
You could check the link below by inputting your telephone number and seeing the BT results for you line.
14-12-2020 7:59 PM - edited 14-12-2020 8:10 PM
Hi I have attached a picture with the outcome of the broadband checker.
Not sure how to get the statistics from the Home Hub. If anyone can point me in the right direction I'll get them.
These are the only stats I could see from the helpdesk page of the home hub:
1. Product name: | Plusnet Hub |
2. Serial number: | +081441+NQ04406611 |
3. Firmware version: | Software version 4.7.5.1.83.8.263 Last updated Unknown |
4. Board version: | Plusnet Hub One |
5. DSL uptime: | 0 days, 01:32:26 |
6. Data rate: | 7637 / 28678 |
7. Maximum data rate: | 7637 / 43404 |
8. Noise margin: | 6.1 / 12.1 |
9. Line attenuation: | 32.3 / 20.4 |
10. Signal attenuation: | 31.5 / 18.4 |
11. Data sent/received: | 159.0 MB / 2.5 GB |
14-12-2020 10:08 PM - edited 14-12-2020 10:10 PM
From those stats your upload speed can’t really go much higher but your download speed can although I’m not sure if it’s worth being on fibre extra over standard fibre.
Either way though try plugging your router into the test socket explained here https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242 and see if your stats change.
Also if you put your landline number into the BT checker here https://www.broadbandchecker.btwholesale.com/#/ADSL what’s the estimates of your line show as under the row VDSL (Clean)?
[edit]
Just seen the picture now. Depending on the outcome of using the test socket, it may be worth downgrading back to standard fibre and/or raising a fault at faults.plus.net asking for an engineer visit to investigate further.
15-12-2020 6:44 PM
Thanks for your help. I opened a call with Plusnet who did the master socket diagnostics and have now raised a fault call with BT Openreach. Let's see what happens now...
4 weeks ago
BT Openreach engineer booked for 4th January 2021 so lets see what happens. I don't think they will be able to do much inside the house as there wasn't a change between when the router was plugged in normally, and when it was plugged directly into the master socket. Let's see what happens....
3 weeks ago
Pre BT Openreach Visit
PPPoE is up - Down Rate=33478Kbps, Up Rate=7819Kbps; SNR Margin Down=10.3dB, Up=6.2dB
3 weeks ago
BT Openreach engineer visited and reset the Digital Line Management.
Now seeing:
5. DSL uptime: | 0 days, 00:05:13 |
6. Data rate: | 7078 / 44039 |
7. Maximum data rate: | 7085 / 44139 |
8. Noise margin: | 6.8 / 6.0 |
9. Line attenuation: | 32.3 / 22.2 |
10. Signal attenuation: | 31.6 / 20.1 |
DSL Line Status
Connection Information
a week ago
Unfortunately a follow up. Since I last posted my line speed has dropped.
Time and Date Message
07:50:09, 16 Jan. (219862.670000) PPPoE is up - Down Rate=33478Kbps, Up Rate=7636Kbps; SNR Margin Down=10.6dB, Up=6.2dB
01:52:40, 14 Jan. (25613.500000) PPPoE is up - Down Rate=38171Kbps, Up Rate=7636Kbps; SNR Margin Down=8.1dB, Up=6.1dB
18:47:52, 13 Jan. ( 124.480000) PPPoE is up - Down Rate=40023Kbps, Up Rate=7570Kbps; SNR Margin Down=6.1dB, Up=6.2dB
18:34:07, 13 Jan. (766090.780000) PPPoE is up - Down Rate=42051Kbps, Up Rate=7696Kbps; SNR Margin Down=5.2dB, Up=5.9dB
02:46:29, 11 Jan. (536433.050000) PPPoE is up - Down Rate=42051Kbps, Up Rate=7696Kbps; SNR Margin Down=6.8dB, Up=6.0dB
20:54:53, 10 Jan. (515336.940000) PPPoE is up - Down Rate=40548Kbps, Up Rate=7600Kbps; SNR Margin Down=6.1dB, Up=6.2dB
01:12:08, 10 Jan. (444377.000000) PPPoE is up - Down Rate=44383Kbps, Up Rate=6931Kbps; SNR Margin Down=6.1dB, Up=6.2dB
17:32:07, 09 Jan. (416775.940000) PPPoE is up - Down Rate=40940Kbps, Up Rate=7644Kbps; SNR Margin Down=7.0dB, Up=6.1dB
00:39:09, 09 Jan. (355998.170000) PPPoE is up - Down Rate=46465Kbps, Up Rate=6928Kbps; SNR Margin Down=6.1dB, Up=6.1dB
18:13:11, 07 Jan. (246442.390000) PPPoE is up - Down Rate=42079Kbps, Up Rate=6469Kbps; SNR Margin Down=6.1dB, Up=6.3dB
