Moved from BT, line reset?
- Moved from BT, line reset?
29-07-2019 2:53 PM
We just moved over today from BT, does that mean that I have moved in the cabinet as Plusnet is owned by BT?
The reason I ask is that my line was stuck at 60.78Mbps on BT and has remained so on Plusnet. I had assumed it would sync and a higher rate and slow if there was an issue, one thing I have never understood, is that I am on a ECI cabinet and am usually connected via fast path without interleave but yet I still don’t sync at full speed.
Could someone check on my line and let me know if there is anything that can be done to give me a chance at getting more line speed?
Re: Moved from BT, line reset?
29-07-2019 3:22 PM
Thanks for getting in touch @Yorkshirelion
When you transfer from one ISP to another you'll retain the same port in all cases as far as I'm aware.
In some cases, the transfer will cause a DLM reset and for your line, I don't think this has happened as your current profile is "0.128M-67M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off" although this won't be holding your connection speed back.
I'd recommend connecting to the test socket if you haven't already done so. Failing that I'd monitor the connection over the next 10 days to see if the speeds increase
29-07-2019 3:32 PM - edited 29-07-2019 3:51 PM
Thanks for the information, I’m not sure why my connection doesn’t increase from this setting, my minimum speed is 58Mbps so I’m not far off of it at 60.78. Is it possible to have the line reset to see if that increases the speed as I had assumed that would happen.
I have tried the test socket before and it doesn’t change my speed, I have a Openreach MK4 with new wiring.
Line stats added as attachment
29-07-2019 3:59 PM
Thanks for getting back to us @Yorkshirelion.
I'm afraid we can only reset FTTC lines in certain circumstances and as it stands your line doesn't meet the criteria as the profile isn't restricting the speeds you're getting
As I've mentioned above I'd recommend monitoring it for now as the speeds may increase down the line but we can't give a guarantee on this
29-07-2019 4:11 PM
Ok thank you for the information,
Looking at my line stats, my maximum is 70 down and 24 up, looking at my line stats what is holding my connection back? Is it the noise margin?
29-07-2019 4:39 PM - edited 29-07-2019 4:50 PM
Hi @Yorkshirelion,
I'm sorry that your sync speed is lower than expected and for any inconvenience that this is causing you.
I've tested your line but the test hasn't picked up the cause of this from here and, as @MatthewWheeler has mentioned, the sync speed is below the top end of the connection profile so it's not the connection profile that's limiting your speed:
GEA Test Detail | |||
Circuit ID | NA | Service ID | BBEUXXXXXXX |
Test Outcome | Pass | ||||
Test Outcome Code | GTC_FTTC_SERVICE_0000 | ||||
Description | GEA service test completed and no fault found . | ||||
Main Fault Location | OK | ||||
Sync Status | In Sync | ||||
Downstream Speed | 60.8 Mbps | ||||
Upstream Speed | 20.0 Mbps | ||||
Appointment Required | N | ||||
Fault Report Advised | N | ||||
NTE Power Status | PowerOn | ||||
Voice Line Test Result | Pass | ||||
Bridge Tap | Not Detected | ||||
Radio Frequency Ingress | Not Detected | ||||
Repetitive Electrical Impulse Noise | Not Detected | ||||
Cross Talk | Not Detected | ||||
Estimated Line Length In Metres | 296.1 | ||||
Upstream Rate Assessment | Very Good | ||||
Downstream Rate Assessment | Low | ||||
Interference Pattern | Not Detected | ||||
Service Impact | No Impact Observed | ||||
Home Wiring Problem | Not Detected | ||||
Downstream Policing Discard Rate | 0.0 | ||||
Customer Traffic Level | Upstream and Downstream Traffic Detected | ||||
Technology | VDSL | ||||
Profile Name | 0.128M-67M Downstream, Error Protection Off - 0.128M-20M Upstream, Error Protection Off | ||||
Time Stamp | 2019-07-16T16:30:00 |
Parameters | MIN | MAX | AVG |
Down Stream Line Rate | 59.9 Mbps | 66.9 Mbps | 66.5 Mbps |
Up Stream Line Rate | 20.0 Mbps | 20.0 Mbps | 20.0 Mbps |
Up Time | 510.0 Sec | 900.0 Sec | 899.6 Sec |
Retrains | 0.0 | 1.0 | 0.0 |
Current and Last 15 Minute Bin Performance | ||
Parameters | Last Traffic Count(Upto 15 mins) | Current Traffic Count(Upto 15 mins) |
Start Time Stamp | 2019-07-29T16:01:30.819+01:00 | 2019-07-29T16:16:30.819+01:00 |
Ingress Code Violation | 0 | 0 |
Egress Code Violation | 0 | 0 |
Errored Seconds | 0 | 0 |
Severely Errored Seconds | 0 | 0 |
Unavailable Seconds | 0 | 0 |
Our suppliers have given the estimate for your line as 69.7 - 80mbps on the broadband availability checker here.
As your services went live with us today, your line is currently undergoing a ten day "training period" during which your sync speed may go up and down as the line tries to find its most stable point. We are unable to investigate speed issues during this training period but please get back in touch if your sync speed hasn't increased to at least 69.7mbps after the ten days.
29-07-2019 6:30 PM
Appreciate the reply and will do.
12-08-2019 6:53 PM - edited 12-08-2019 6:54 PM
Hi again,
My line has indeed improved since the initial 60Mbps, not 69Mbps but close. Although I noticed that it did disconnect today;
I’m not sure why my upload is so much better than my download with full speed and a better noise margin. What I don’t understand and I’m not complaining is why my line has no interleaving on, if it did have interleaving on would it reach higher download speeds or be more stable?
thanks
12-08-2019 10:09 PM
I am shocked at the lack of support from PN on this thread.
1. There is no 10 day training period for FTTC lines.
2. Why has no one picked up on the banding applied to the line:
3. If the line is performing below the estimates, why has the banding not been removed or an engineer sent to sort the internal wiring if that is the issue?
@Yorkshirelion Do you have a filtered Master Socket? Or any master socket with a test socket below a faceplate which you may have been asked to run your router from with an ADSL filter?
12-08-2019 10:53 PM
Thanks for the reply, I have a Openreach MK4 Master Socket 5C, the wiring inside the socket is new as it was replaced by an engineer a few years ago, I don’t use any extensions or even a landline. I don’t gain anymore speed from the test socket, however I have just been leaving the router alone as to not lose any speed. I thought it was banding and it makes sense after reading your message I had not picked it up from the initial response which included the information.
12-08-2019 11:30 PM
@Yorkshirelion Just one more thing, does your max attainable rate increase in the test socket?
It looks like your connection may not be stable, unless you can account from the DSL uptime on your stats?
Perhaps PN could provide a Radius log of your line which may then explain the banding.
13-08-2019 10:17 AM
Hi @Yorkshirelion , @Mustrum
Here is a RADIUS graph:
There also doesn't seem to be any banding at play;
Test OutcomePass
Test Outcome CodeGTC_FTTC_SERVICE_0000
DescriptionGEA service test completed and no fault found .
Main Fault LocationOK
Sync StatusIn Sync
Downstream Speed68.3 Mbps
Upstream Speed20.0 Mbps
Appointment RequiredN
Fault Report AdvisedN
NTE Power StatusPowerOn
Voice Line Test ResultPass
Bridge TapNot Detected
Radio Frequency IngressNot Detected
Repetitive Electrical Impulse NoiseNot Detected
Cross TalkNot Detected
Estimated Line Length In Metres324.7
Upstream Rate AssessmentVery Good
Downstream Rate AssessmentReasonable
Interference PatternRegular Interference Observed Daily
Service ImpactRetrains Observed
Interference Duration Longest OccurrenceFrom12:45to13:00
Interference LocationUnknown
Interference Observed In Days0
Home Wiring ProblemNot Detected
Downstream Policing Discard Rate0.0
Customer Traffic LevelUpstream and Downstream Traffic Detected
TechnologyVDSL
Profile Name0.128M-80M Downstream, Interleaving Low - 0.128M-20M Upstream, Error Protection Off
Kind Regards,
MoR
13-08-2019 11:13 AM
Hi, thanks for the reply.
So does my line have some interleaving on it now, when I do a ping to say bbc it looks the same as before at 8ms, in the past when my line has had interleaving my ping increased. Still doesn’t seem very stable however;
13-08-2019 1:29 PM
13-08-2019 3:42 PM
The reason I ask about interleaving is that in the last line test that was posted it said the following;
How do I find out why my line is disconnecting?
