More Speed Drop!
- More Speed Drop!
More Speed Drop!
16-01-2016 4:04 PM
It was around 47-48 meg, now it's only 41!
Is it something to do with this new network rubbish?
First & foremost the modem hasn't resynced since the 12th of November, ie 65 days uptime. So it cant't be a DLM issue.
It is also syncing at 53,999 kbps (almost 54 meg?). So why is my actual speed 12 meg below this?
Have ran the BT second stage test & it shows my ip profile as 42 meg, there is only 2-3 meg between min & max.
As I said it was much higher than this.
How come, using my phone No, BT can offer a min guaranteed download speed of 54 meg?
Some snapshots.
Re: More Speed Drop!
16-01-2016 4:25 PM
https://www.plus.net/my.html?action=data_transfer_speed
16-01-2016 4:41 PM
it's the BT profile that has dropped.
16-01-2016 5:09 PM
16-01-2016 5:29 PM
As I said the actual modem has had an unbroken connection for two months, didn't really want to bring the DLM into play.
16-01-2016 6:38 PM
16-01-2016 7:36 PM
Probably since the new version of Windows 10 was installed.
Now have re-installed it all & now found the modem actually re-synced at 3.50am on Monday morning (11/01) retrain reason 1.
It synced at 44275kbps, 9meg lower than previously (53999kbps)!
Why did this happen? Reckon it's all to do with this new network change & ties up with the Lottery site issues.
Additionally I see G.INP has been turned off, previously it was enabled.
What on earth is going on?
Ever heard of the saying, "If it ain't broke, don't fix it"?
16-01-2016 8:06 PM
Quote from: buseng12 Why did this happen? Reckon it's all to do with this new network change & ties up with the Lottery site issues.
No idea why you think this.
The connection from your house to the fibre DSLAM has nothing to do with Plusnet's new network or the National Lottery website.
16-01-2016 8:46 PM
As far as I know I had a rock solid connection for almost 2 months & then all these problems.
The Lottery site issue DEFINITELY started this week.
16-01-2016 9:19 PM
Lost 10mbit on my Download speed, and around 4Mbit on my upload and all they have said so far is...
“connection & speed are all performing within expectation”.
Their expectation surely because it definitely is not mine.
