Mobile Fibre Broadband!
- Mobile Fibre Broadband!
05-03-2015 3:10 AM
For the past 3 months now I have been having slow net and at some points I am batter off when I get suspended dew to a late payment as plus net has not pulled there finger out to make customers pick there billing date....
It all ways happens when I am sat on the 31......... IPs the 81.... IPs are fine, I also have a ticket open as you could not test my line to find the fault.. Hell I buffer so much I use my mobile to watch things as its more faster and its only 3G.
You also have a problem with ping with in your network as the ping is never steady so I do not get a steady speed.
Man up and suck it in and deal with your problems.
dick:blue Restricted information removed.
Message 1 of 2
(488 Views)
1 REPLY 1
Re: Mobile Fibre Broadband!
05-03-2015 12:19 PM
I appreciate you've mentioned having this problem for a few months, however unless you tell us you're having issues there's nothing we can do to help. I can see that you reported a fault to us a couple of days ago, so we'll get that picked up and tested.
Are you connected via a wired or wireless connection? What speeds are you getting when you're having the problems?
Message 2 of 2
(276 Views)
