Minimum guaranteed line speed has been changed.
smallblueplanet
Hi
when I signed up to fibre in Jan I was promised:
"We estimate your broadband speed should be between 20Mbps and 31Mbps and your minimum guaranteed access line speed is 16.9Mbps."
However I have today just checked my fibre speed and find not only am I getting way below that but my IP Profile for the line is now set at 14.77 Mbps.
Download speedachieved during the test was - 12.9 Mbps
 For your connection, the acceptable range of speedsis 10.34 Mbps-14.77 Mbps .
 Additional Information:
 IP Profile for your line is - 14.77 Mbps
How and when has this been changed please as it is not what I signed up for, and fairly recently I was getting download speed in the 20Mbps?
15 REPLIES 15
smallblueplanet
Re: Minimum guaranteed line speed has been changed.
Your broadband service
  • Product: Unlimited Fibre
  • Estimated Download Range: 15 - 24Mbps
  • Estimated Upload Range: 2.5 - 4Mbps
  • Minimum Guaranteed Speed: 12.3Mbps
  • Current Line Speed (Download): 14.7Mbps
Fixes: 419
Your minimum guaranteed speed has not changed. This is not the same as your IP profile, which varies with your actual synch speed.
You probably have a fault so you need to go through the standard fault finding procedures.
1. Remove the front off the BT Master socket to expose the test socket.
2. Plug a wired telephone in here and do a quiet line test by dialling 17070 then option 2. If there's any background noise then report a phone fault.
3. Plug a filter in to the test socket and connect this to your router. With a computer connected to the router via an Ethernet cable complete the BT speed test.  http://speedtest.btwholesale.com/ If this is showing your speed is low then go on and complete the further diagnostics to record the results then report a broadband fault.
Fixes: 419
@smallblueplanet
Your latest post throws new light on this situation. Where did the new information come from?
smallblueplanet
The first min speed guarantee was from my sign up email.
The speed tast was from BT Wholesale.
The second post I just put in to bump the thread as its from my Account details, which I assumed someone like @Gandalf or other staff could see anyway.
smallblueplanet
Sorry @Baldrick1 didn't mean to be short in my previous post, I was rushing.
Just done another BTW speed test and it says
Download Speed (Mbps): 20.06
Upload Speed (Mbps) : 3.14
Ping Latency (ms): 13
But Further Diagnostics says
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
smallblueplanet
Well now I get this from BTW speedtest
 Download speedachieved during the test was - 20.09 Mbps
 For your connection, the acceptable range of speedsis 20 Mbps-21.39 Mbps .
 IP Profile for your line is - 21.39 Mbps
But still saying this in my account:
Is there a problem with the line again @Gandalf ?
MatthewWheeler
Fixes: 479
Thanks for getting in touch @smallblueplanet
Our tests are showing a potential fault that would need an engineer visit to investigate further.
Can you raise a fault online by going here and then post back once you've done so?
This will allow us to get that picked up straight away for you
 Matthew Wheeler
smallblueplanet
Hi @MatthewWheeler thanks for looking at this.
I think I've done as you asked. As you can probably see from my account there have been previous problems with my (and my neighbours) line.
When Iook at my account it now (oddly) says.
  • Current Line Speed (Download): 21.3Mbps
Fixes: 419
@smallblueplanet
I am totally confused. You say you have low speeds. @MatthewWheeler  says that you have a potential fault that needs investigating. Repeated BT speed tests report that your download speed is in the middle of your expected speed range.
What tests are you doing that convinces you that you still have a problem? Note that only wired Ethernet speed tests are relevant in this context.
smallblueplanet
@Baldrick1 I'm just doing as asked to by @MatthewWheeler (our line has had many problems previously).
I have no idea what info he is looking at but for some reason the minimum guaranteed line speed on my account (and the line speed) dropped appreciably yesterday.
Now the BTW test further diagnostics says this, I've no idea what is causing it.
Download speedachieved during the test was - 20.05 Mbps
Mads
Fixes: 79
Hey @smallblueplanet,
Thanks for getting back to us.
Just to make sure, can you confirm you are connected via Ethernet when doing these speed tests? Are you also connected into your test socket? If not, please get connected by following this info and then let us know the results of your speed tests.
Thanks.
smallblueplanet
Hi, I can,t do any more tests atm.
What I am particularly bothered about is the fact that, as I said in the first post, the minimum speed guaranteed by Plusnet has been dropped from c.16 mbps to c12mbps. Why has this been changed? It is not the minimum speed I signed up for?
Fixes: 1,600
Hi @smallblueplanet Not in the office at the moment but it’d be difficult to advise definitively the reason behind your account showing a lower minimum guaranteed speed(MGS) than agreed.
I wouldn’t worry about that too much because we’d realistically only use your MGS for contractual purposes i.e. if you’re wanting to leave and when/if doing so, we’ll obviously bear in mind the MGS you specifically agreed.
For fault purposes we’d use the current expectations/estimates of your line as shown at http://dslchecker.bt.com
If you’ve raised a fault ticket we’ll pick that up either this weekend or early next week at the latest and investigate further.
Hope this helps.
smallblueplanet
Thanks @Gandalf You're a star. Don't want to get all contractual, just didn't want to end up paying 'extra' for rubbish speeds on this line. Smiley All seems fine now tbh.
