Minimum guaranteed fibre speed
- Re: Minimum guaranteed fibre speed
20-07-2018 4:18 AM
20-07-2018 10:37 AM
Hi Duncan, welcome to the forums.
Due to the technology in use, the speed you will receive will vary depending on the length and quality of your line, which is why the 67mbps (which is the average that Plusnet customers get) is different to your estimates.
As for your speeds, are they sync speeds or speeds from a speed test? If from a speed test is that with a wired or wireless connection?
Plusnet would release you from your contract if your sync speeds are below the minimum guaranteed access speed if you have given them a chance to fix it and it is confirmed that you can't get that speed. The first step for that would be to run through the troubleshooting here.
20-07-2018 2:00 PM
Hi @Duncan7,
I'm sorry to hear that you're experiencing these issues. I've taken a look into your account today and upon testing your line I've discovered a potential external fault located within your local network. I've raised this to our suppliers for further investigation now and more information regarding this issue can be found via the ticket I have raised on your account, here.
