Minimum guaranteed access line speed
monk8
Hello,
Just upgraded to Fibre Extra and on the chat I was told my minimum guaranteed access line speed would be 74Mbps.
See Question #172536790.
According to the estimated line speeds etc. I should be getting Estimated line speed 80Mb
My Current line speed is only 60.4 Mb. The main reason I went ahead with the upgrade was because of the minimum guaranteed access line speed of 74Mbps.
Is it something my end or is it a plusnet issue?
Cheers,
Sam
1 REPLY
Fixes: 205
Re: Minimum guaranteed access line speed
Sorry to hear your speeds are lower than expected.
Our tests aren't showing any cause for this so I'd recommend raising a fault here
 Matthew Wheeler
