Mini cab on pole...what sort of speeds?
- Re: Mini cab on pole...what sort of speeds?
14-10-2014 10:37 PM
Had a new BT pole put at the bottom of th garden with a mini green cabinet on it....its not more than about 30 meters from the house.
Will they just do FTTP from that, or run copper for the last length?
What sort of speeds would I get from that?
Message 1 of 4
(1,307 Views)
3 REPLIES 3
15-10-2014 4:23 PM
Surely someone else has a connnection like this and can give an answer? Or a pn representative can prise the details from bt etc....???
Message 2 of 4
(926 Views)
15-10-2014 4:42 PM
I don't know but I assume that the mini green cab feeds a number of properties.
If this is the case it is probably be a subsidiary cab and if or when fibre is enabled it will use a new can adjacent to the master cab and it will be copper from there
I have a similar situation except the subsidiary cab in at ground level - the main cab is marked as 20 and the subsidiary can as 20/1
Message 3 of 4
(926 Views)
15-10-2014 4:48 PM
Of course, a picture tells a thousand words
Message 4 of 4
(926 Views)
