Microsoft Teams drops calls on new laptop
- Re: Microsoft Teams drops calls on new laptop
20-05-2021 2:48 PM
Hi, I've just changed jobs and have received a new laptop. I now have an issue where any teams calls on this new laptop keep dropping out. This hasn't happened with other laptops I've used, and mine is the only one in the house affected. My wife and son are not having problems with there's even when we're on calls at the same time, mine is the only one dropping. Could there be an incompatibility between the new laptops network card or something and the plusnet hub one router I have? My current firmware is - Software version 4.7.5.1.83.8.263 Last updated 15/09/19
20-05-2021 2:59 PM
Is the new laptop the only one using the 5ghz band by any chance ?
20-05-2021 3:18 PM
20-05-2021 3:30 PM
I've reported this to work and they've suggested a router incompatibility hence I'm checking here
Sounds like a 'fob off' to me. In what respect are they suggesting its incompatible ?
20-05-2021 4:31 PM
It's definitely a fob off.
The main reason I was posting on here was to see if it could by any chance be firmware or something given that mine is 2019.
20-05-2021 6:40 PM
There is a pre-release firmware that addresses a problem with the 5ghz wireless, hence my initial question.
The only other issue that crops up is a DNS lookup failure. I would have thought that would affect all systems not just your laptop.
Do you use a VPN on the work laptop, I would guess so. If so , is the VPN dropping and taking the Teams call with it, rather than just the Teams call dropping out ?
20-05-2021 6:45 PM
