Massive speed loss
thevaleyard
Massive speed loss
Hey there, I have a line capable of downstream speeds in excess of 100 Mb, and upstream speeds greater than 40 Mb.
I am currently on the 40/20 service with Plusnet. I am easily able to reach those speeds and that was the case when I first signed up last year.
However there is a massive slowdown today, crawling to around 9 Mb down and 0.8 Mb up.
Here is a screenshot of a recent speedtest using the BT Wholesale site, http://i.imgur.com/6aw1VDz.png
Any help would be great thanks
Faizan786
Re: Massive speed loss
Looks like a line problem there buddy, go and raise a fault.
AshPowell
Looks like you're downloading on Steam, do you have the same problem with other programs closed?
Fixes: 181
As AshPowell has advised we'd need a result with nothing running in the background to investigate further.
 Matthew Wheeler
