Massive speed loss on second interface.
Fixes: 38
I logged into my router this morning to add a new machine to the network when I spotted this:
Needless to say I'm not that impressed anyone at Plusnet have any comments?
Fixes: 167
Re: Massive speed loss on second interface.
Not sure what you want us to say? It looks like something has caused the speed to drop, if you can PM me with which line it is I'll test it and see if there's anything obvious though.
 Chris Parr
 Plusnet Staff
Fixes: 38
You’ve said exactly what I was hoping to hear, i.e. it’s not right and needs looking in to so thanks @Chris PM sent.
Fixes: 167
Can you run through the fault checker on that account for me please, https://faults.plus.net
Testing the line has found an issue so once you've completed the fault check I'll get this raised and reported.
Description Impairment in copper joint detected most likely close to customer premises. Please continue to submit a trouble report.
Main Fault Location CA
Sync Status In Sync
Downstream Speed 46.9 Mbps
Upstream Speed 16.2 Mbps
Resolution/Recommendation: Please report fault to BTW for OR investigation.
 Chris Parr
 Plusnet Staff
Fixes: 38
Done, and ticket raised.
Fixes: 167
Great thanks, I'll go get that pushed through and reply shortly.
 Chris Parr
 Plusnet Staff
Fixes: 167
Here are the connection logs FYI
 Chris Parr
 Plusnet Staff
Fixes: 167
Ticket updated, we're being asked for an engineer visit. Can you reply to the ticket with the info asked and I'll pick this up.
 Chris Parr
 Plusnet Staff
Fixes: 38
Done, and thanks for that graph, didn't know it was that bad. The (dis)advantage of have two connections.
Fixes: 167
Can you let me know when you want me to try and get one booked, or is it just asap?
 Chris Parr
 Plusnet Staff
Fixes: 38
BTOR Guy left some time ago, with the following result having reset the port (I think that's what he said).
Apparently if I'm not happy with this I've to arrange for a 'Fibre Line Boost' to arrange for a UG engineer to come along and re-make every connection! I know I can be a bit of a git at times but I'm not that bad (yet). I'll wait for now and see if there's any degradation on the line and take it from there, so thanks to @Chris for a speedy result.
Fixes: 167
It's looking better, not quite up to full speed but definitely an improvement. Keep an eye on it and let's see how it goes.
 Chris Parr
 Plusnet Staff
Fixes: 38
@Chris  - Logging in to the router I now see this.
So I have no complaint (for the moment at least) Smiley
Fixes: 167
Ah excellent Smiley
 Chris Parr
 Plusnet Staff
